Adding a Laundry Sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by srubin1701, Nov 20, 2006.
  1. srubin1701
    srubin1701 New Member
    Nov 20, 2006
    So I want to add a laundry sink next to the washing machine and dryer. I can T into the PVC supply lines or come up through the basement...
    The problem is on the Drain side.
    Can I simply T into the vertical drain line below where the washing machine pumps its discharge into? ... I'm only 2 feet from the drain.
    As another alternative, I could drill the waste line down into the basement and tie into the stack there, but I'm not sure about the vent.
    Another thought was to use an AAV, although I get the impression that plumbers arent' particularly happy with them....
    Anythoughts are appreciated, I'd like to install this over the thanksgiving break.
  2. Terry
    Aug 17, 2004
    [​IMG]
    Many places will want a vent for both fixtures.
    I think that if you use an AAV, that it would be better for the sink, than the washer.
    Hammer arrestors on the water supply are a good idea too.
Similar Threads: Adding Laundry
Plumbing Forum, Professional & DIY Advice Adding Laundry sink, and need professional advise. Feb 7, 2016
Plumbing Forum, Professional & DIY Advice Adding laundry sink and washer to existing standpipe May 10, 2014
Plumbing Forum, Professional & DIY Advice Adding a sink to a laundry room Nov 3, 2013
Plumbing Forum, Professional & DIY Advice Adding Laundry Sink... Help Needed Mar 6, 2013
Plumbing Forum, Professional & DIY Advice adding laundry upstairs May 26, 2012
