Adding a 1/2 bath in basement - this rough in look ok?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jeff1675, Apr 15, 2013.
  1. jeff1675
    jeff1675 New Member
    Apr 15, 2013
    Syracuse, NY
    New on the forum here but have lurked a long time. Great info from a lot of knowledgeable people. Thanks.
    Just wanted a look at a pretty basic 1/2 bath addition in a basement in upstate NY.
    Tapped into existing 3" drain line under slab. About 2-3' to the right is the main vertical stack coming down from above floors. On the wall to the right is an existing mud-sink with its own vent.
    I understand that because I am within 6' of the stack the toilet will not need its own vent.
    This look ok?
  2. Terry
    Aug 17, 2004
    The toilets from above will affect the lower toilet if it's not vented.
    You need a vent between the toilet and the waste stack or waste horizontal.
  4. jeff1675
    jeff1675 New Member
    Apr 15, 2013
    Syracuse, NY
    Thanks Terry
    "will affect" meaning it wont work or something more subtle? This is the case even with 3" lines and the vertical stack less than 3' away from this new wye? Have been told that close it wouldn't need its own vent.
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Look at it this way- the stack is not and cannot be used as a vent if there is any drainage coming into it from above.
    It does not matter what size or how far away it is.
  6. hj
    quote; Have been told that close it wouldn't need its own vent.
    Who told you this? Someone from Home Depot?
Similar Threads: Adding bath
Plumbing Forum, Professional & DIY Advice Advice needed - Bathroom Drain/Vent adding vertical santee Yesterday at 7:49 AM
Plumbing Forum, Professional & DIY Advice Drain layout for adding double sink to existing bathroom Oct 22, 2015
Plumbing Forum, Professional & DIY Advice Adding a branch line for addition of Master bathroom Aug 4, 2015
Plumbing Forum, Professional & DIY Advice Adding a bathroom - but can't reach exisiting septic system Jul 15, 2015
Plumbing Forum, Professional & DIY Advice Pipe size when adding bathroom? Jul 1, 2015
