Add-on bathroom rough plumbing remodel
danfman
Wisconsin
I'm remodeling my 1st floor bathroom and looking for advice on the rough plumbing. There use to be a toilet at left rear of the room, and a shower in the right center. I'd like to place the new toilet where the shower previously was, and in the left rear corner we'd like to add a sink. My biggest question is about the new toilet's return line. I only have access to the joist the current return line is in and the two to the right (stairs are in the way of the joists furthest to the right). I worry about the integrity of the floor joists if I cut a hole that large through boards.
FYI this bathroom is a former back porch, so underneath the joists are about 3' gap before the outside ground.
Any suggestions to relieve this problem? Any other issues anyone thinks I'm missing?
You can take up to a third of a joist, leaving 2" on the bottom and 2" on the top. No notching.
The line that vents the toilet now would server as a wet vent if you install a lav there. The wet vent portion of the lav is 2" and of course the venting is 2" for the toilet. If you have 2x10 joists there it may be doable. Or if you are three feet off the ground, you can always add support.
