Add cross-framing under toilet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by speede541, Jul 21, 2010.
  1. speede541
    speede541 Member
    May 1, 2010
    Oakland
    As part of my little project I'm replacing a small square of rotted floor under a toilet -- a double layer of 3/4" ply, in fact -- spanning about 14" between parallel joists.
    Do any of you routinely install cross bracing to span between the joists for a bit of extra support under the toilet? It seems pretty beefy without, but I'm curious about best practices.
  2. jadnashua
    Ply is strongest if it spans at least two bays (i.e., attached to three joists). So, since you'll have some edges unsupported, consider blocking along those edges.
  4. jimbo
    jimbo Plumber
    I agree with jad's comments. I have found over the years, that for a drywall repair, or a flooring repair....a bigger patch is actually easier, stronger, and ends up better on the cosmetic front.
    A 14" square of plywood, just supported by a 3/4" lip at the joist, will be prone to sag along the open edges,and pry up on the supported edge.
Similar Threads: cross-framing under
Plumbing Forum, Professional & DIY Advice Our seemingly never ending sewer line under the house problem Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Basement under counter sump pump Feb 7, 2017
Plumbing Forum, Professional & DIY Advice P-Trap Under Floor Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Under sink plumbing Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Overflow tube under sink that seems to no longer exist Jan 17, 2017
