Add bathtub - second floor remodel
beniciaDIY
East Bay , CA
Looking to add bathtub in second floor remodel. I have access to 1.5 inch horizontal shower drain line (approx. 4 ft from proposed bathtub drain) in the floor that empties into 2" vertical drain in the wall (approx. 7 ft from proposed tube drain), the main soil stack is also in the wall on this side of the bathroom. On the opposite side of the bathroom, I have a vertical 1.5 inch line, what I assume is a vent line from the downstairs bath that exits separately from the main stack through the roof in the opposite wall (approx. 2 ft from the proposed new tube drain).
My question is to which line do I connect the new bathtub drain? Can I drain and vent to the closest vent line from downstairs? Can I wye into the existing shower drain and use the closer vent pipe to vent? Or do I need to drain to the vertical pipe above or below the shower line and vent to the closer vent pipe? None of the above?
You CANNOT connect to the downstairs vent, and SHOULD not connect to the shower drain line. You CAN connect to the vertical drain line, if you do it correctly.
beniciaDIY
East Bay , CA
hj,
Thanks. Figured it had to be the hardest option. As the horizontal run is close to 7 ft ad I need 1/4 inch per ft slope, I assume I cannot use the 2 inch vertical that the shower is using and have to tie into the 3 inch soil stack?
