ADA Recommendation
Discussion in 'Toilet Forum discussions' started by elgato, Jul 31, 2009.
  1. elgato
    elgato Member
    Jan 20, 2007
    Phoenix, AZ
    I need to replace my Parents' standard toilet with a reasonably priced ADA height model. They would prefer a round bowl. An ADA Drake with round bowl and Sanigloss would be perfect but it appears that it does not exist.
    Are there any good ADA height units with a round bowl?
    They may have to settle for a DrakeII elong. with Sanigloss.
    Recommendations?
    Thank You
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I don't believe round bowls are available in ADA height from any manufacturer. Elongated bowls are pretty much the normal bowl for most folks, they are "male friendly" and take up little, if any more space. The Drake will be an excellent choice.
  4. Gary Swart
    Sep 1, 2004
    Yakima WA
    Correction to my last post. There are some ADA height toilets that have round bowls. The Toto Drake does not come in round.
  5. Terry
    Aug 17, 2004
    I sell the Toto Entrada for those looking for a tall bowl and round front
    26-5/8" long, 16-1/8" high
    CST243EF
    [​IMG]
    The Drake ADA is 28" long and 16-1/2" high
    CST744EL
    CST744SL
    Promenade
    CST423EFG Tall 16-1/8" round bowl with Sanagloss Ecoflush
    CST423SFG Tall 16-1/8" round bowl with Sanagloss G-Max
  6. jadnashua
    I think an ADA rating on a toilet requires elongated...those are required for commercial use. There are various toilets that are the right height, but I think it's the combination of height and shape that lets it get an ADA rating. Not all toilets are created equal, and an elongated toilet bowl may not be longer than an older round one. The older ones needed a bigger tank pushing it out further into the room (often 5+ gallons), and the new ones a max of 1.6g. Now, pretty much all new toilets hold more water than that to give it more oomph, but they dont' dump it all, but nowhere near the 5+ gallons of old.
  7. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    ADA can be regular rim as well as elongated it is the height including the seat it needs to be "17-19".
    This is why there used to be a 18" high bowl, because the guy who was writing the codes didn't realize it included a seat, when they found out this was wrong (a long time later) they changed the specs to 16-1/2" as the standard for ADA bowls.
  8. elgato
    elgato Member
    Jan 20, 2007
    Phoenix, AZ
    What a nightmare!
    Stopped in at Winnelson on a Monday to get a quote on a Promenade 423SFG. $*** with a week to 10 days delivery. Ordered it on Friday and checked back the following Friday. "we cant find your order, will call you back" No return call. Same thing on the following Monday. Talked to them again on Tue. "we cant find your order and estimated delivery time is four weeks"
    So it looks like I need a second choice candidate that is actually available. How does the Dalton compare to the G-Max models? Is it possible that the new design Champion 4's are OK? Stay away from Cimmarons, correct?
    Thanks
  9. Terry
    Aug 17, 2004
    The round or the elongated Entrada works fine.
    TOTO Entrada CST243EF
    Or the Cimarron would work too.
Similar Threads: Recommendation
Toilet Forum discussions Toilet recommendation for narrow space Dec 26, 2016
Toilet Forum discussions Recommendation for best wall mounted toilet with tank in the wall... Oct 6, 2016
Toilet Forum discussions 2 piece toilet recommendation Oct 4, 2016
Toilet Forum discussions Recommendation - Round bowl Jul 15, 2016
Toilet Forum discussions Recommendation for quiet Toto Apr 19, 2016
