actual door opening width
Discussion in 'Remodel Forum & Blog' started by lmei007, Mar 19, 2013.
  1. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
    I measured the width of my existing door panel and got 27-3/4", it is a 28" wide door or 30" wide door?
    or
    what's the actual door opening width for a 28" wide door? I need to know if the opening is wide enough for a table which is 26" wide.
  2. jadnashua
    It's a 28" door. But, the actual opening is smaller because of the door stops. If you take the door off, it should just make it through. With it on, you'd have to subtract at least the thickness of the door.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    It is a 28" ( trade size 2-4, meaning 2'4"). Then is was planed about 1/4" at install. So your opening between jambs is close to 28", but subtract about 3/8" each sde for stops.
    A table can be fudged through a much smaller opening, buy easing the legs "around the corner" at the side opposite the hinges
  5. hj
    Your table is 26" wide and the door opening is 27 3/4". What is the problem? The only problem would be if the door does not "swing" open far enough to give you the full opening, in which case, remove the hinge pins and put the door off to the side somewhere.
Similar Threads: actual door
Remodel Forum & Blog Fast and Final spackle actually works. It dries like it's been sanded. Oct 6, 2014
Remodel Forum & Blog Minimum gap between shower door and header Sep 2, 2016
Remodel Forum & Blog Best Patio Door Manufacturer Sep 6, 2015
Remodel Forum & Blog Tiled Doorway In Adjoining Areas Feb 24, 2015
Remodel Forum & Blog Good Source For Door Hardware Sep 15, 2014
