Acrylic Tub - Wooden Base
Discussion in 'Shower & Bathtub Forum & Blog' started by mehlhorn, Mar 3, 2010.
  1. mehlhorn
    mehlhorn New Member
    Jan 6, 2010
    Brampton Ontario
    Hello All,
    I pulled out a galvanized tub and am replacing it with a new acrylic tub with a wooden base. The old tub was basically sitting in place with a few washers holding it to the vertical studs (behind the old shower kit).
    Does the new tub just sit there also? I notice that this tub it considerably lighter than the original and may effect installation. Also, I am not comfortable screwing the new washers in to the studs to hold the tub in place for fear of damaging the new, more fragile acrylic tub.
    Any thoughts?
    Mike
  2. mehlhorn
    mehlhorn New Member
    Jan 6, 2010
    Brampton Ontario
    I forgot to ask if it is recommended that I screw it into the floor throught the wooden base. I am worried it the tub shifts it will ruin the tile.
  4. jadnashua
    Many people set the tub in a mortar bed that supports it to prevent stress cracks and make it feel more substantial. Then, a large head nail or two (or maybe a screw with a large washer) lapping over the edge to help anchor it until you get the tile in. There are ledger boards underneath the rim to provide support if someone were to sit on the edge. Depending on the size of the tile and the height of the tiling flange of the tub, some people notch the studs so that the lip is in line with the studs. Then, you can overlap the cement board down to about 1/4" of the horizontal tub surface, which locks the edges in and not have the bottom of the cbu bow out. If the tile will be supported at least half, then you can stop the cbu at the lip and not worry about the overlap. Put a vapor barrier behind the cbu and run it down over the tiling flange. Cut it off after you put up the cbu. Check out www.johnbridge.com for help with the tiling. Make sure that the tub sits level...the mortar underneath gives you the opportunity to adjust it so it is level in addition to supporting it.
  5. hj
    If the wood base sits on the floor and levels the tub, that is usually all that is necessary. Once everything is in place and the tile and walls are installed, the tub should not be able to move in any direction. BUT, if the tub is "fragile", then why would you want to install it in the first place?
  6. PlumbPowerHouse
    PlumbPowerHouse Plumber
    Dec 10, 2009
    South Carolina
    I would level the tub, place some mortar under the tub, and screw some drywall screws into the tub into the studs.
Similar Threads: Acrylic Wooden
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Just installed acrylic Delta Tub and 3 piece surround (attach to studs type) Dec 11, 2016
Shower & Bathtub Forum & Blog New acrylic airtub installation, where to put ledger? Nov 25, 2016
Shower & Bathtub Forum & Blog Acrylic shower pan with no mortar underneath May 7, 2016
