Acid neutralizer question
Discussion in 'Water Softener Forum, problems, installation and r' started by Bob999, Jul 23, 2009.
  1. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    I have a backwashing acid neutralizer with a 12 x 48 tank.
    My question is how much Calcite media should be maintained in the tank?
  2. Gary Slusser
    Retired
    You should add mineral when the treated water pH starts going below 7.0 at high flow rates.
  4. Bob999
    Jul 4, 2009
    Pennsylvania
    The media is Calcite, no corosex. The raw pH is 6.5.
  5. Bob999
    Jul 4, 2009
    Pennsylvania
    I suppose your pH raises to around 7.3-.4? --It depends on flow rate. At high flow rates it will drop to 7.2 or less while at low flow rates it will be 7.8-8.0,
    2 people in home, 4.5 baths, 1" plumbing in to AN filter and out to softener. Welll produces 30 gpm and pump produces 25 gpm. Hardness goes from about 5 gpg raw to 7-8 gpg after AN filter.
    pH characteristic of water is that it measures acidic immediately after being drawn but if allowed to sit for a day the pH will rise to above 7--perhaps as high as 7.5.
  6. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    The minimum will be up for debate, however, the maximum level of calcite should provide a clearance of 18" or greater from the control head.
  7. Gary Slusser
    Retired
    I've never seen 'calcite' alone raise pH to more than 7.3 or so.
    I still say the time to add more mineral is when the max peak demand flow rate shows a pH of 7.0 or less.
    99K, you say that is debatable, when would you suggest Bob999 adds mineral?
  8. Gary Slusser
    Retired
    IMO most if not all homeowners will have a tough time getting an accurate CO2 test.
    If a bed needs to be replaced, I 'd say there was insufficient backwashing but the question was when to add more mineral.
  9. Bob999
    Jul 4, 2009
    Pennsylvania
    I already have my AN tank and I am commited to filling it as needed.
    So--What is the "correct level" to which the AN should be filled?
    Why do "Most neutralizers need a re bed every 2 years." and how do I tell if my filter needs a rebed?
  10. Gary Slusser
    Retired
    I've sold many AN filters over the last 22 years and I've never had a customer have a problem with channeling, probably because the backwash is done properly and frequently enough to prevent channeling. Backwashing is the only way to cure channeling.
    That will also prevent "impurities" from getting down in the bed. But what are these impurities actually?
  11. Bob999
    Jul 4, 2009
    Pennsylvania
    Gary,
    What do you recommend for backwashing my AN filter? It is a 12 x 48 tank, media is calcite only, and the DLFC is 7 gpm.
  12. Gary Slusser
    Retired
    Depending on how many people and any iron, backwash it every 3-4 days. Two people no iron, 4-6 days.
    The 7 gpm may be too small.
    What brand and model control valve are you using?
  13. Bob999
    Jul 4, 2009
    Pennsylvania
    The control valve is a ProFloSE. As best I can determine 7gpm is the largest flow button available for my configuration (5/8" OD for the flow control button). I have very small amounts of iron (0.1 mg/l) and manganese (0.16 mg/l). 2 people in home.
    How long should the backwash and rinse be?
  14. Gary Slusser
    Retired
    I'd go 14-16 minutes if one backwash and then 6-8 minutes rinse. If two backwashes 6-8 and then 6-8 again and 6-8 rinse.
    You could do away with the DLFC button and get a 10 gpm Dole flow control. But that's not necessary for a 2.0 cuft. And actually, you could have used a 1.5' and got a deeper bed depth, and a top dome hole type tank. IIRC 2.0' doesn't come with a TDH tank right? And a 12" x 48" doesn't get the proper freeboard area; I use 12 x 52" tanks but not for AN filters. You need bed depth, not a wider column.
  15. Bob999
    Jul 4, 2009
    Pennsylvania
    The 12 x 48 tank I have does have a top dome hole--it is a Structural Brand tank.
    Thanks for the advice on the backwash.
  16. Gary Slusser
    Retired
    I can never remember about the 2.0' tanks.
    You're welcome.
  17. Bob999
    Jul 4, 2009
    Pennsylvania
    Is your recommendation that this backwash/rinse be done every 3 to 4 days because of the iron (0.1 mg/l) and manganese (0.16 mg/l) in my water?
  18. Gary Slusser
    Retired
    Based on what you have said so far you could.
  19. shas
    shas New Member
    May 24, 2010
    Maryland
    Help with backwashing
    I need to add a couple 50 lb bags of Calcite to my system. What do I need to know about backwashing? I'm not sure how to do it -- don't recall if the installer ever mentioned it. I don't believe I have an automatic system. I have a top-flow tank with no electronic controls at the top. Other than shutting valves and funneling in the bags, what do I need to know about backwashing? Thanks in advance.
  20. Gary Slusser
    Retired
    You have an upflow filter meaning there is no control valve so the water goes down the distributor tube and up through the mineral and out to the fixtures. So you need to run water somewhere other than in a septic tank to get rid of any discolored water after refilling the tank with new mineral.
Similar Threads: Acid neutralizer
Water Softener Forum, problems, installation and r Draining Softener and Acid Neutralizer to Outside Feb 6, 2016
Water Softener Forum, problems, installation and r Is it safe to run chlorine water into acid neutralizer from well shock treatment? May 21, 2013
Water Softener Forum, problems, installation and r Low water pressure from water coming out of acid neutralizer. Bypass pressure is OK May 19, 2013
Water Softener Forum, problems, installation and r Recommendations on Acid Neutralizers Dec 10, 2012
Water Softener Forum, problems, installation and r Please help with acid neutralizer questions Apr 6, 2012
