Accidental hole in 3" PVC Drain Pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Shoun, Oct 1, 2006.
  1. Shoun
    Shoun New Member
    Oct 1, 2006
    I drilled a 3/16" hole in my PVC drain pipe by accident when hanging a towel rack. Should I drill out the hole to 1/2" and glue in a plug? The pipe is tight between two walls and I'm not sure if I can get two couplers in to replace the whole section of pipe.
    What's the best way to fix this? Does anybody make 1/4" plugs??
    Thanks for your help!
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Does this 3" pipe serve as a vent from this point on above or is there another bath group?
  4. Cass
    Cass Plumber
    Nov 12, 2005
    There are a few things you can do
    1 take a hot, almost red hot, knife or similar and melt the plastic pipe to fill / cover the hole.
    2 get a 1/4" drill and tap and thread the hole and install a plug.
    3 fill the hole with epoxy
    4 cut the pipe in 2 places about 4" on either side of the hole and install a new peice of pipe with 2 banded couplings.
  5. Shoun
    Shoun New Member
    Oct 1, 2006
    Thank you
    Thanks, I'll go with the 1/4" tap and plug option. It seems easier for to guarantee a joint without water leak.
Similar Threads: Accidental hole
Plumbing Forum, Professional & DIY Advice Accidentally drilled hole in PVC pipe Mar 1, 2005
Plumbing Forum, Professional & DIY Advice Whole house drain enzyme? Jan 26, 2017
Plumbing Forum, Professional & DIY Advice Whole House Water Filter HELP...super confused Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Re-Plumbing Whole House Dec 26, 2016
Plumbing Forum, Professional & DIY Advice Pin hole fix above slab Nov 21, 2016
