Access Panel. New Shower Valves
Discussion in 'Shower & Bathtub Forum & Blog' started by thinkly, May 29, 2008.
  1. thinkly
    thinkly New Member
    May 21, 2008
    Kansas
    After recently remodeling my main floor bath, my basement shower (shower only) must have felt jealous because the hot valve started to leak. This has been an ongoing issue for a few years.
    The first plumber tried to replace the stems (think that is correct term) but he said the threads were damaged and it would be a temporary fix. That lasted about 2 years, and then the next plumber came in.
    I am not sure what he did a year ago but he stopped it for about 6 months. Fast forward to now and the hot handle drips water all of the time. It is now time to replace the ENTIRE valves. (I have seperate valves)
    I'm tired if throwing money away. Anyway my plan is to open up a hole tonight to prepare for plumbers arrival in the morning. I bought a 14" X 14" access panel at Lowes to cover the hole.
    My question is: Will this hole be big enough for them to operate in? Also should i just center the two valves in the hole or is it better to have them one way or the other.
    I have never changed one, so i am asking those of you that have. Thanks.
  2. hj
    valves
    Maybe you just need better plumbers. I would want to see the valves or at least a picture to determine if they have been blowing smoke at you. Stripped stems are corrected by installing new ones, and once that is done there are no more "stripped stems that will not last long".
  4. thinkly
    thinkly New Member
    May 21, 2008
    Kansas
    What do the stems thread into? This is what i was told is stripped.
  5. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    The stems thread into the valve body. I agree that you should post a picture.
  6. hj
    stems
    They screw into the valve body and the only way they could be stripped would be if the servicing person was the one who stripped them, and it would almost have to be done on purpose. More often a "stripped" body is because the person is using the wrong stems and the threads are not correct, which means they do not tighten properly. Getting the correct stems usually cures that problem.
Similar Threads: Access Panel
Shower & Bathtub Forum & Blog Tile an Access Panel?? Oct 20, 2016
Shower & Bathtub Forum & Blog Best location for air tub access panel, front or floor? Apr 4, 2013
Shower & Bathtub Forum & Blog Preferred Makes/Models - Tileover Access Panels Apr 3, 2013
Shower & Bathtub Forum & Blog Jacuzzi Tub Access Panel - Building, Access and Sound Proofing May 19, 2012
Shower & Bathtub Forum & Blog Access panels and wet walls. May 18, 2012
