Access hole?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by willl, Jul 8, 2008.
  1. willl
    willl New Member
    Jul 18, 2005
    North Dakota
    :) Hi, Do you need an access hole in a shower and also what about a tub? What exactly do you need access to in a shower and also a tub? Can I get by without one? Thank you
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    More info would be helpful
    Is the tub a hot tub.
    Do you have shut off valves that are in the wall or under the tub.
    It is very helpful having access to the pipes in the future.
  4. jadnashua
    Very useful, rarely required unless you have a whirlpool or air tub.
  5. willl
    willl New Member
    Jul 18, 2005
    North Dakota
    OK
    Tub is going to be a drop in tub (might make it a jacuzzi tub). It is going to be constructing with a deck that is tiled and the tub drops in the deck. Shower will be simply a shower that has tile on walls and floor. I am not to sure where the shut off valves will be but I suppose I will need shut off valves for each one of these fixtures and if I need to install shut off valves for each fixture then I need an access to them. Thanks
  6. willl
    willl New Member
    Jul 18, 2005
    North Dakota
    For another question would you guys object to having a window in a shower/tub enclosure. If you need to know I live in a very very cold climate during the winter and warm during the summer. Thanks:cool:
  7. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
    Fine with me. With a big window, you could call it a "garden shower" and add big bucks to the resale value. In any case, I'll bet there's special glass and glazing appropriate for the shower environment (i.e., tempered glass) and your location (i.e., super-insulated).
  8. jadnashua
    Building a shower that doesn't leak with a window in it can be done. You might consider a glass block window replacement, though. Some places require an opening window, though (it's usually either a fan or an openable window). Check out www.johnbridge.com for help with tiling things.
Similar Threads: Access hole
Plumbing Forum, Professional & DIY Advice Access to tub faucet - size of hole in drywall? Nov 7, 2012
Plumbing Forum, Professional & DIY Advice Tub shoe gasket replacement when no access? Oct 5, 2016
Plumbing Forum, Professional & DIY Advice Heard Noise Behind Tub. No Access to Failed Part. How Hosed Am I? Nov 29, 2015
Plumbing Forum, Professional & DIY Advice Possible to use Ikea vanity if water and drain access on side? Sep 30, 2015
Plumbing Forum, Professional & DIY Advice Ceiling Access Panel??? Jul 26, 2015
