AC thermostat ??
Discussion in 'HVAC Heating & Cooling' started by rayh78, Jul 17, 2011.
  1. rayh78
    rayh78 Member
    Sep 15, 2008
    Colonial Heights, Virginia
    Have a rental property been working on that now vacant. Janitrol 2 ton heat pump about 6 years old.
    Noticed I would temp at 84 when I left at night. Following morning I get there and the actaul temp reads 77. Look like a cheap no name thermstat so replaced with a used Honeywell that worked good before. Had stored in my shed because switch to a programable one in my own home.
    This seemed to work fine for days. When there working during the day I turn down to about 77 and then back up when I leave to about 84. Then a few times found the place at 77 the next morning. According to the display and verified with a laser therm I have.
    Called my AC guy. He saids it has to be the termostat.
    So buy a new honeywell thermostat and install. A few days later its doing the same.
    Either something wrong my AC guy does not know about. Or at night when I leave its able to hold the 77 temp without the ac cutting on for 12 hours with the thermstat turned up to 84.
    It does seem to turn on and off like it should during the day when working there.
    Does this make any sense?
    thanks
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I don't know what overnight temps are like there but it is possible that it is simply holding the temp. You could of course disconnect the thermostat or flip off the breaker when you leave to see. Some smart theormostats will keep stats on usage so installing a smart stat could tell you if it's running at night. You could also leave some tissue paper on the air registers and see if the fan blows them off.
  4. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If it is a smart thermostat.
    Once you set the temperature you have to hit the "Hold Temp" , or it will revert to "Run Program"
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I can see nothing in the OP that would suggest he has a smart programmable thermostat.
  6. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I guess that I assumed it was.
    Sorry, Bad Me...
  7. rayh78
    rayh78 Member
    Sep 15, 2008
    Yes, just NON programable
Similar Threads: thermostat
HVAC Heating & Cooling Aprilaire 700 humidifier with Nest thermostat Feb 9, 2017
HVAC Heating & Cooling Recommend A Thermostat? Feb 8, 2017
HVAC Heating & Cooling Relocating thermostat to allow heating with wood stove? Jan 17, 2017
HVAC Heating & Cooling How to control the heat using the thermostat? Nov 20, 2016
HVAC Heating & Cooling Thermostat won't power on Oct 30, 2016
