AC Cable to NM (ROMEX®)
Discussion in 'Electrical Forum discussion & Blog' started by mrhoades, Jan 30, 2009.
  1. mrhoades
    mrhoades New Member
    Apr 7, 2008
    My house built in the late 40's uses old BX cable (no bonding strip) and an 1980's renovation using AC cable w/the bonding strip. I would like to begin finishing my basement.... Am I allowed to add new circuits using NM (ROMEX®). If so how do I ground inside the fuse box?
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    If an armored cable is being used I hope that there is a metal box also. The equipment grounding conductor of the NM cable bonds to this metal box
  4. RayP
    RayP Vocational Instructor
    Jan 20, 2009
    Syracuse NY
    Yes
    You can as long as you have the correct ground. Easy way to do this is replace your box and grounding electrode, and also the service cable. This sounds hard but is not. You can pay to have an electrician do it for $500-$1000, where I am (upstate NY). Homeowners can do it themselves here, after claiming to have the skill. You then need to have it inspected before cut in by the utility company.
  5. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Why would you need to do all this just to convert from AC to MN?
  6. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    The old armored cable without the bonding strip: That stuff is grounded. When I test that wiring it shows ground.
    Is it not allowed to connect new bx to the old?
  7. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    This thread should be a good one... :D
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    If the AC cable does not contain a bonding strip then you cannot use the jacket as an equipment ground, nor extend those circuits with NM. Just start installing new circuits with NM back to the panel. Which I believe was your orginal question to begin with, Inside the panel the grounds and neutral conductors tie to the same bus.
  9. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    I dont know why your suggesting any of that...
Similar Threads: Cable (ROMEX®)
Electrical Forum discussion & Blog Using "MC Lite" (aluminum jacket) cable connectors Oct 13, 2016
Electrical Forum discussion & Blog Switching between AC and MC cable? Oct 13, 2016
Electrical Forum discussion & Blog Underground cable Oct 2, 2016
Electrical Forum discussion & Blog Surface mounted armored cable, or EMT? Sep 21, 2016
Electrical Forum discussion & Blog Limitations on NM cable in tall structures? Aug 18, 2016
