ABS vs. PVC- marine application- building a shark cage
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by fishinwithagun, Oct 21, 2009.
  1. fishinwithagun
    fishinwithagun New Member
    Oct 21, 2009
    California
    Hi all, well I don't think this is an "everyday plumbing question", but I am desiring a pretty specific application for pipe and need to know what you all think.
    I am building a shark diving cage, and want it to be inexpensive. This rules out aluminum or other metals; you know, things that sane people would use. Anyway, I am looking to construct it out of either PVC or ABS, but I'm not sure what would be best for this application. The cage will be held together at the corners with fittings- tee connecting to street elbow- the structure will be a 7x5x5 ft rectangle. Every 14 inches up the vertical frame will be a tee connecting horizontally to the opposite side of the cage. Probably going to go with 2" pipe.
    The question is: Given the fact the piping will be used in the water(but not kept there permanently), have some sun exposure, and possibly be bitten/rammed by a shark, is it better to go with PVC or ABS? I basically require durability.
    Ryan
    PS. This is not a joke. Can I please get some serious replies?
  2. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    In doesn'tmatter which is more durable, you are going to be the sharks lunch in either case.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    How big are the sharks ? :D
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    First I would at least use SCH 80 pipe and you do realize that if you leave no way for water to fill the pipe it will float.
    John
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Your nuts.....
  7. hj
    cage
    Your heirs will be happy to know that by saving money on the cage you were able to leave them a little larger inheritance. Sharks bend metal cages, your PVC one will only slow them down, regardless of how you "reinforce" it. A 7' section of 2" pipe with 14" spacing will allow the shark to go right through it with just a little acceleration run. Please get a competency hearing before proceeding with your plans.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Can you post a video of you using it?:rolleyes:
  9. jimbo
    jimbo Plumber
    Well, I certainly agree that you are about to be shark bait.
    But specifically on your question: Pressure rated PVC, shc. 40 or preferably sch. 80, is solid plastic. Many DWV pipes, both ABS and PVC, are cellular foam core. Not as much structural strength there.
    Water is not a problem, but PVC turns brittle after sun exposure. This would be over a year or more, and we don't expect you will last long enough to worry about it.
  10. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    Being in the water with a few sharks is no big deal. I'm usually swimming toward them rather than away--the sharks are the ones who are skittish. Being in the water with a lot of big sharks, chumming and such is not on my activity list though.
    This thread reminds me of a Far Side cartoon about "Don's discount shark cages." I wouldn't trust plastic pipe for something like this. I've never seen PVC pipe hold up well as a structural member for a framework. Cheap soccer goals are often put together this way and it seems like they are always broken.
  11. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    This question reminds me of the old movie clips showing early attempts a flying. The contraptions that had flapping wings, guys with wings jumping from cliffs, and on and on. Although these guys risked breaking their necks, they weren't going to be eaten by sharks. I really suspect you are jerking our collective chains with this idiotic question, but if you are serious, are you older than eight or nine and does your mommy allow you to go in the deep end of the pool? If you are for real, make your PVC/ABS cage and hang a bag of fish guts inside. Then lower the cage into shark infested water and see how long it will take for the sharks to smash into it.:eek:
  12. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I'd have someone weld me one out of rebar for dirt cheap before making one from plastic pipe.
  13. hj
    cage
    Preferably #4 rebar minimum, and preferably #6 if the boat has a big enough crane.
  14. Ian Gills
    Jul 24, 2007
    USA
    I have green, yellow, red and brown nuts...you know...down stairs.
  15. fishinwithagun
    Oct 21, 2009
    California
    Thanks for the feedback and the laughs guys... I like the pictures! In hindsight, PVC is a no brainer... went to HD today and got some SCH 40. The reason why I wasn't sure on PVC vs. ABS was my friend said "get the black PVC(ABS), it's stronger." It sure didn't feel that way, he obviously didn't know what he was talking about- but you guys do!
    I'm still working on a few things, one being how to get the cage to sink. I don't really want to drill holes through the PVC as that could weaken it; perhaps I can find a 4 way fitting so that as the cage goes in the water the pipes fill up. Also, the spacing between each horizontal bar; HJ brings up a good point, 14 in. is probably too big. Bad things happen when a shark gets his head caught in the cage!
    However, the sharks I would be diving with would not be that big. Off southern California we have blue sharks, makos, threshers and great whites. I don't think I would dive with a shark bigger than 8'. I know a spot where some smaller great whites have been hanging out <8' that I am excited to dive with; better hope mom doesn't show up though <15ft! :eek:
    Again, thanks for the opinions. I won't let you guys down... pictures of the finished product as well as in the water with sharks are on the way; give me a few weeks. :)
  16. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    You have to be kidding right? I mean seriously. You're worried about drilling holes in the pvc because it will weaken it...... This doesn't make sense to me because if you were worried about strength you'd be going with something much more durable then sched 40 PVC.
    If I were you I would of ATLEAST gone with a 3" sched 80 main frame and 2" sched 80 for re-enforcing bars.
    But then again if I were you I wouldn't be stupid enough to swim with great whites (of any size) in a PVC shark cage...
    Oh and you should try and paint that cage to keep the UV light off it. PVC likes to shatter once it's been exposed to the sun for a bit instead of bending.
    Good luck to you though!:cool:
  17. Cookie
    Cookie .
    Oct 7, 2005
    My head hurts from laughing.
  18. ChuckS
    ChuckS New Member
    Mar 17, 2009
    Aurora, CO
    Is that a pre-existing condition?
    I hope his health care doesn't deny his coverage.
  19. Cookie
    Cookie .
    Oct 7, 2005
  20. Redwood
    Dec 15, 2007
    Service Plumber
    I nominate this thread for this weeks Darwin Was Right Award...:eek:
    [​IMG]
  21. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I second that motion and call for the vote ;)
Similar Threads: PVC- marine
Plumbing Forum, Professional & DIY Advice Oohrah Happy Birthday Marines 232 Years Nov 10, 2007
