ABS to PVC Septic Connections
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chuck b, May 3, 2011.
  1. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    Need to connect 3" PVC to a 3" black ABS pipe which exits an old septic system at a newly acquired cottage.
    The pipe run is through a open crawl space under the cottage. Do I use SCH 30 or SCH 40 pipe. Advantages or disadvantages of either?
    Also, would the 3" Black ABS pipe match SCH 30 or 40? I will of course be making my rough drain connections throughout the cabin from the PVC.
    I have purchased the "Green Bottle" ABS to PVC cement. Is it true that you only primer the PVC and NOT the ABS (hearing that it dissolves ABS)?
    Thanks.
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Fernco will have list of products,you cannot glue pvc to abs,pvc is solvent weld,abs is glued non compatable materials. fernco might have solve your problem.
    Clay
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    There are only two approved methods for joining PVC and ABS and glue ain't either of them. You either need a banded coupling (indoors) a non banded coupling (outdoors) or male and female adapters.
Similar Threads: Septic Connections
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Roots growing into septic tank Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Help with septic drainage field possible leakage on hill Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Distance from septic exit to main vent? Aug 28, 2016
