ABS into cast iron hub with neoprene gasket HELP
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by filipo, Sep 3, 2006.
  1. filipo
    filipo New Member
    Sep 3, 2006
    I had to replace my bathroom floor, and in doing so removed the closet flange under the toilet, as well the lead pipe connecting the flange to the cast iron soil pipe. (Lead was joined with lead/oakum, which took me decades to pull out. :D) Now I have a length of ABS I need to run from the flange to the cast iron hub. I was told a neoprene gasket, which fits on the inside of the bell, would be the best option. But godd*mn if it isn't impossible to squeeze the ABS into the gasket once the gasket's inside the hub.
    Anyone have any advice on this? I thought about some kind of lever, or using a come-along to ratchet it down in there, but the joint is in a very tight space, and right above an elbow -- so no room to maneuver much of these machinations.
    None of the local plumbers will come out for this minor job -- or if they will, not until three months from now. Help!
    Phil
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    cut the hub off
    the best option is to just go get a cast iron cutter and cut the hub off
    then put a 3 or 4 inch fernco fitting on the end of the cast
    and tie in the pvc to it.....
    Now beating that plastic into the hub can be done if you use some
    sort of lubricant (lots of bear grease) and a short piece of pvc pipe to hit with
    a sledje hammer and 2x4 to keep the pipe from shattering.
    then coupling onto the pvc ppe you have beat into
    the hub.....
    its lots and lots of funn and very manly....
    I try to avoid it at all costs
  4. filipo
    filipo New Member
    Sep 3, 2006
    yeah, but
    Thanks Mark. The issue with cutting the cast iron is that it's an elbow -- a very short one at that. And there's no real room to cut it, either -- especially not using one of those giant cutters. In addition, that elbow feeds into another segment of cast iron, which I could pull out as well, but then I'm back to square one if I just pull off the elbow.
    I lubed the sh!t out of the ABS and the gasket, but that didn't help much. Or at all, really. And there's no room for sledge hammers and such -- I'm right under the floor, with about 4 or 5 inches between the pipe's top end and the subfloor. Though I guess I could get a longer section of ABS and just cut it off at the top once I've jammed it into the neoprene...
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
  6. filipo
    filipo New Member
    Sep 3, 2006
    Verdeboy -- I'm an Albuquerque kid myself. Nice to see some Nuevo Mexicanos among the forumites...
    Thanks for the link, but after reading it I'm especially sure that cutting the cast iron won't work. Too small a space for the snap cutter, and too small to get a grinder or saw blade all the way around the diameter. (Plus, there's a whole lot of other piping right nearby that I'd have to remove and then replace in order to get a clear shot at the cast iron.)
    So far it sounds like the neoprene gasket is the wrong idea, but I'm still crossing my fingers...
    Thanks,
    Phil
  7. PhilUpNorth
    PhilUpNorth Engineer
    Sep 25, 2005
    Engineer
    Montreal, Canada
  8. filipo
    filipo New Member
    Sep 3, 2006
    So where can I find that tool?
    Thanks for the link, Northern Phil. The manual features a special pulling tool for joining with neoprene -- basically a big lever that braces against the bell of the hub. They of course recommend their own brand, the "Charlotte Pipe pulling tool part #EPT-920." But likely there are other, similar tools out there.
    Anyone have an idea where I might find, rent or borrow one of these things?
    Thanks,
    Not-so-Northern Phil
  9. hj
    pipe
    Cutting the hub off would leave you with an unusable curved piece of pipe/fitting to try to connect to. The joint is designed to be tight, but if you have the wrong sized insert, such as one for cast iron pipe, it could be too small for your ABS.
  10. filipo
    filipo New Member
    Sep 3, 2006
    right gasket size?
    Thanks HJ. Agreed about cutting the pipe. As far as having the right fitting, is there a list somewhere that lays out proper sizes or model numbers? Or should it say somewhere on the gasket itself?
    Thanks,
    Phil
  11. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Gasket
    Like someone else said, you have to check the gasket. You don't have XH stamped in any of your iron, do you? If so a standard gasket won't work. You have to make sure the the plastic is square, file the outside edge on a slight taper, and use a lot of soap [dish soap is fine]. Lots of luck.
Similar Threads: cast iron
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
