ABS in Highrise buildings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by robertpatterson, Oct 9, 2009.
  1. robertpatterson
    robertpatterson New Member
    Jun 10, 2009
    I live in a condo with 15 floors and built in the 1970's. The drain piping from the roof that goes through the interior walls needs to be updated. Can it be changed from Cast Iron to ABS.
    The uniform building code says at you cannot use ABS in buildings more than 4 stories in Zone 1. What does Zone 1 mean and what is recommended?
    Thanks.
  2. jadnashua
    My guess is no, but a call to the building inspector would settle it quickly.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Two things. Cast iron will last for many years. Surely your CI is not bad after less than 40 years. Secondly, ABS and PVC drains are very noisy. I would think that if you made the change, you would be swamped with angry condo owners. Even is allowed, I would urge you to get some more opinions.
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    It is a noise and fire issue. Mostly fire though. Zone 1 is usually commerical which typically a 5 story condo building is.
  6. hj
    plastic
    It is almost all a fire issue. Plastic pipes emit a toxic smoke when they burn, and that is not good to have on the upper levels of a high rise. 3 or 4 floors is marginal, but at least the occupants have a good chance of evacuating before the levels become critical.
  7. robertpatterson
    Jun 10, 2009
    Thanks for all your help!
    Wondering if Code says that all areas above a certain floor you cannot install abs piping or if it allows for a few pipes. Say there are two pipes every 20 feet.
  8. hj
    code
    The code cannot anticipate every nuance you would like it to. It cannot say, for example, that you cannot use a lot of plastic above the stated floor, but if you want to stick a little piece in here and there it is okay. Therefore, it says once you reach the third or fourth floor, depending on the version, it cannot be used, period. And if the building is fire rated, plastic cannot be used ANYWHERE in the building.
Similar Threads: Highrise buildings
Plumbing Forum, Professional & DIY Advice 4" DWV done in ABS in underground garage in a highrise Feb 14, 2011
Plumbing Forum, Professional & DIY Advice Galvanized waste rules in highrise building Jan 8, 2011
Plumbing Forum, Professional & DIY Advice --Waste From High Rise Buildings-- Dec 14, 2005
