ABS fitting inside concrete footing?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jeffeverde, Oct 17, 2009.
  1. jeffeverde
    jeffeverde Member
    Sep 21, 2009
    L.A.
    -Slab-on-grade floor
    -toilet backs up to an exterior wall
    My vent stack/end-of-line clean-out will come up through the footing/slab. In a typical above-grade install, the closet bend would point back to the wall and T into the stack, like this-
    [​IMG]
    But how do I accomdate the requirement for a 2"-oversize sleeve in the footing penetration, if I've got a fitting buried in the footing? Is this a case where a horizontal vent is permitted due to structural/grade restrictions? like this-
    [​IMG]
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Are you sure you're even allowed to place the plumbing inside the footing like that? Where I am from this certainly wouldn't be allowed.
  4. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Abs fitting inside concrete
    You first picture is correct !
    You just put a 3" x 2" reducer bushing into the top of your clean out tee and
    extend the 2" vent up from there, also you get foam wrap and make 3 or 4
    turns around the abs pipe and fittings where ever they are buried or cross
    though the concrete footing and slab !
    This gives room for the abs and concrete to slide without breaking the abs
    like in thermal expansion of the abs when you run hot water though it !
    This go's for all abs concrete penetrations
  5. jeffeverde
    jeffeverde Member
    Sep 21, 2009
    L.A.
    That's what I'm familiar with. But new code (not sure if it's UPC or California bldg code - which is a mix of UPC and our own mod's due to the seisimic zones here), is calling for all footing penetrations to be sleeved in pipe 2" larger than the diameter of the line you're running.
    Guess I'll be visiting the bld'g dept tomorrow to find out how they want it.
  6. jeffeverde
    jeffeverde Member
    Sep 21, 2009
    L.A.
    Then how do you get your plumbing into exterior walls? Keep in mind that here in California, 99.999% of our construction is slab-on-grade, so there's no joist space to run the ground-floor plumbing through like you'd have with stem-wall or pier construction.
  7. hj
    vent
    Put your Y BETWEEN the elbow and the toilet and run the vent back to and up inside the wall.
  8. jeffeverde
    jeffeverde Member
    Sep 21, 2009
    L.A.
    Latest California Building Code requires all footing penetrations to be sleeved in 2-sizes larrger pipe. But apparently many (most?) local AHJ's aren't enforcing it, because it's not practical in situations like mine, where there's a tub, shower or W.C. along an exterior wall.
    So it's standard layout and wrap in foam. I did drop the combi to the bottom of the stack -- I'm thinking the 18" free-fall from the toilet horn should make for a very effective flush :D
    Thanks, all, for your help.
Similar Threads: fitting inside
Plumbing Forum, Professional & DIY Advice Compression Fittings Allowed Inside Wall? May 12, 2008
Plumbing Forum, Professional & DIY Advice Gray Poly barbed fittings keep leaking. on my 3rd try. What's wrong? Yesterday at 4:05 PM
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice What fittings are there for polybutylene pipes? Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Uponor PEX with non-ProPEX fittings Nov 1, 2016
