ABS/DWV repair
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Plumbcatastrophe, Feb 13, 2006.
  1. Plumbcatastrophe
    Plumbcatastrophe New Member
    Jan 22, 2006
    On a 2" line, old 20 year ABS, it's leaking around the joints a little bit. Is there something you can buy to rejoin or meld or some kind of sleeve or should it be replaced? This particular union is the straight extension fitting into a Y. I tried dobbing some ABS cement around it but that really didnt help. Suggestions?
  2. Terry
    Aug 17, 2004
    Sometimes, ABS will crack over time.
    If your fitting is leaking, I would cut it out and replace it.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Especially if you are in California or Arizona, you are in the time frame when there was some bad ABS pipe around. Cracked at the fittings. There was a class action suit, but it may be over. See if you can read a manufacturer's name printed on the pipe.
    Regardless, the best recommendation is to remove and replace the damaged parts. Anything less will always be suspect.
  5. Plumbcatastrophe
    Jan 22, 2006
    ABS Lawsuit
    Thanks, I found that stuff. The brand on the pipe says "Standard" but it was installed around the time here in Nevada. Might be something to all that.
Similar Threads: ABS/DWV repair
Plumbing Forum, Professional & DIY Advice Any idea what a plumber might charge for repairing a copper pipe? Sunday at 12:59 PM
Plumbing Forum, Professional & DIY Advice Lead Bend Repair? Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Faucet Handle Removal & Leak Repair Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Kohler Forte Tall Single Lav Repair, K-10217 Jan 14, 2017
Plumbing Forum, Professional & DIY Advice Tub Drain Leak - Where to repair Jan 9, 2017
