Above Ground Well Pump Cracked in the Cold
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mikewags, Dec 12, 2013.
  1. mikewags
    mikewags New Member
    Dec 10, 2013
    Oregon
    The title says it all - i believe my well pump under extreme cold cracked because it had water inside. Took some photos.
    Based on the photos am i out of luck? Need to replace the whole pump?
    Any information/advice would help. Thanks
  2. mikewags
    mikewags New Member
    Dec 10, 2013
    Oregon
    the model/etc stamp on the pump
  4. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Only two words to describe that pump- old and older. Looks like you missed that big crack in the 1st post huh?
    My advice is to buy a whole new pump/motor unit. Choose a good quality pump with a cast-iron housing and not one sold by the big box stores.
  5. mikewags
    mikewags New Member
    Dec 10, 2013
    Oregon
    Yeah, i didn't notice that crack until I saw a puddle of water under the pump yesterday. Really sucks because the thing was working fine all summer long. I really should have prepared for this weather better.
    What do you think I will spend to replace this with a comparable pump?
    This cold snap has been a real learning experience - unfortunately I had to learn the hard way :(
    Let me know if you can suggest any brands/places to buy... Thanks.
  6. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    I have had the best luck with Goulds jet pumps.
  7. mikewags
    mikewags New Member
    Dec 10, 2013
    Oregon
    As it stands now this pump is toast correct?
    I'm not trying to sound cheap or anything, but was wondering if that crack could be welded back up.
    I will probably be buying a new one/replacement - but I guess I'm just wondering if this thing is a paper weight now (an ancient paper weight).
  8. ankhseeker
    ankhseeker Member
    Oct 2, 2013
    San Pablo, California
    Cast isn't weldable that I know of. Looks like you need a new pressure gauge too.
  9. mikewags
    mikewags New Member
    Dec 10, 2013
    Oregon
    Pressure gauge has gone back down to 0 since things have thawed out.
    Any help/direction of a new pump to by would be greatly appreciated. I'm just looking for something comprable to this pump to do the job - this is just for yard irrigation/sprinklers - and there is a 30 gallon pressure tank in the mix.
    Here is a photo of the current pump specs:
    HP: 1
    PH: 1
    I'm looking at the goulds jet pumps here: Looking to spend maybe around $200 - $400 if i can.
    http://www.aquascience.net/jet-pumps/
    Thanks again guys.
  10. craigpump
    Apr 12, 2012
    Cast iron can be welded with nickel rod or brazed, but as old as that pump is, you are far better off replacing it.
Similar Threads: Above Ground
Pumps and Tanks Well Forum & Blog. Water is life. Above ground tanks of different heights. May 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. I need an "air eliminator" valve to "temporally" install above ground for a well sys. Mar 27, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Above Ground "Well" Project Oct 2, 2013
Pumps and Tanks Well Forum & Blog. Water is life. has anyone "insulated" under their above ground pool? 3" layer of mulch? Jun 2, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Above ground pool pump question. Garden hose?? May 31, 2013
