A stream on the property, well distance?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Scuba_Dave, Jan 7, 2009.
  1. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I have a stream on my property - about 45' from my house
    Most times its little more then 3-4" deep. Its more of a large drainage system during rainstorms
    Is there a min distance for a shallow well installation?
    Of course the ground slopes off near the stream
    So to me that might be the ideal place near my shed
    I'm not looking for drinking water, I want to water gardens, maybe supply water to the toilets, fill the pool, 1,000g pond system, possibly refill a hot tub, water the veggie garden
    For every gallon of water we use, we are charged a certain fee as a sewer rate for Town sewer
    Thanks
  2. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    WV
    Bumping because I also would like to know the answer to this .
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    The vertical distance from the water to the pump is important. The shorter the better. Pipe size matters depending on how far it is to the pump from the water.
    To filter the water to keep things out of the pump that won't pass through the jet and impeller will be difficult with only 4" of water. Can a hole be dug that would stay open to allow a filter?
    bob...
  5. hj
    well
    If the ground is saturated a drive point may give the water you need and also filter it.
  6. WV Hillbilly
    Aug 1, 2008
    WV
    I think the OP was asking & what I would like to know , is there a minimum distance allowed by code or standard regulations ? The minimum distance being between a stream & a drilled or driven well . In my case my water well is less than 100 feet slightly upslope of a small seasonal stream .
  7. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I know a lot of cottages on ponds use the pond water for household water. We have Town sewer, so that's not a problem
    A friend has some well equipment - never got it working
    I may see if I can "borrow" it & give it a try
    Just not sure what he has
Similar Threads: stream property
Pumps and Tanks Well Forum & Blog relief valve releasing water stream Apr 14, 2012
Pumps and Tanks Well Forum & Blog Underground Stream? Apr 22, 2007
Pumps and Tanks Well Forum & Blog Shared well pump needing separate usage on parceled property Jul 25, 2005
