A simple question
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rj8214, Jul 20, 2007.
  1. rj8214
    rj8214 New Member
    Jul 17, 2007
    I've been reading the threads posted here and I tell you just from what I've read, I have been able to solve all of my problems but one.
    What side of the pump does the psi gage go. Intake or out?
    Please advice,
    Thanks
    Rob
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    The pressure switch and guage usually go between the pump output and the pressure tank, and usually closer to the tank than the pump.
    If the suction side of the pump had any guage at all, it would be for vacuum rather than pressure.
  4. kingfisher
    kingfisher New Member
    Jul 21, 2007
    Question
    Hello,
    The output or pressure side of the pump is where the gauge should be located.
    Kingfisher
  5. rj8214
    rj8214 New Member
    Jul 17, 2007
    Thank you
    Thanks guys. You've been a great help. My project has come to a close. The gauge is set to 40 PSI to turn the system off and a differential of 20 PSI to turn it on. All systems are a go.
    Thanks for the forum and thanks for your help.
    Rob
Similar Threads: simple question
Pumps and Tanks Well Forum & Blog. Water is life. Simple Shallow Well Question (but beyond me) Jun 21, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Simple question Oct 27, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Simple Pump in 4" casing - no pitless adapter Jul 29, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Well water cleansing - Simple methods Mar 4, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Pitless Adapter Fitting Question Friday at 11:31 AM
