a plumber installed this for me -- was it done properly?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Pickngrin, Jan 1, 2012.
  1. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Happy New Year. I had a plumber come to install a drain for a utility sink in my garage. This is what he did. I'm not a plumber, but I thought that the sink drain had to run into a vertical drain. The drain stack is behind that wall stud, to the left of the fitting that he installed. The copper pipe running through the drywall is the drain from the bathroom sink. I asked him about the angling of the drain and he said that it didn't have to be angled. That doesn't seem consistent with what I've read, but again, I'm not a plumber. He told me to make a little riser for the plastic sink out of 2 x 4. Is this OK or do I have a problem? By the way, I figured out not to use the sink on the other side of the wall (he did not install the sink itself) before the sink is attached, but he never bothered to tell me not to.
    Thanks.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Looks like it was done by the lowest bidder. A sink drain needs to be 2", and it needs to be pitched to the main. It cannot be connected to the main stack without a vent if there are other fixtures draining into the stack above it.
    Next time you hire someone, insist that they get a permit and inspection done prior to paying.
    Are you sure he was a plumber?
  4. Pipewrench
    Pipewrench In the Trades
    Mar 28, 2011
    Service plumber
    Jackson MS
    So did he just access th copper drain then put that tee in the line? I'm not sure what you're talking about on the 2x4 riser. I'm not crazy about the rubber fernco either. Looks terrible. I would have used a male and female fittings to make the transition to pvc for better support. Other than looking cheap it should work ok for a shop sink. Looks like your dryer vent is running along the floor there also. Is that gonna be in the way??? Good luck buddy
  5. jadnashua
    The coupling he used is not approved for internal use - it needs to be a banded coupling. Plus, I don't think it would pass as it doesn't appear to be vented, reductions in size are not permitted, and a T is not the proper fitting to attach into a drain line, even if the rest was okay. while a permit may add some to the cost, it also ensures you get it done right the first time in most cases.
  6. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Was the work done for less than $100?
  7. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    No it was not done properly. It could have been a little worse, but not much.
  8. Dunbar Plumbing
    Apr 18, 2005
    I've been put in this situation before, where "doing it right" involves a considerable amount of money and effort to do it correctly.
    To do it correctly,
    Get to where that drain stack is, remove the tee and install a tee that is 2" by the size of that stack. From there, you either design the piping with incorporation of a wye with the ability to vent those fixtures individually or not.
    The work shows they just added a tee into an existing trap arm off the other fixture.
    To do the job correctly, there's considerably more money involved to do it right.
  9. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    That's ugly man, just plain ugly and, it in no way meets code.
  10. dlarrivee
    Jun 28, 2009
    Canada
    The title of the thread asks the question.
    If it costs too much, maybe the sink doesn't go in.
  11. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The plumber could replace rest of the copper with pvc and make a profit on the scrap copper alone. :p
  12. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    He also used a compression fitting in the copper line that will not be accessible.
    John
  13. dlarrivee
    Jun 28, 2009
    Canada
    I just noticed the compression fitting.
    He must be one hell of a "plumber".
  14. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Ugh. Yeah, my gut told me this was not right. He claimed to be licensed although I never asked for a license #. I don't have much experience hiring plumbers and have learned my lesson from this experience. I figured it was an easy job for anyone competent (competent being the key word here) and didn't worry too much about it. He drives a van advertising drain cleaning. Perhaps he lies about being a plumber. Anyhow, I am actually going to email him and tell him I received feedback that there are problems with this installation. My main concern now is the compression fittings inside the wall, in case they leak. I'm going to tell him that's a problem. I doubt he will rectify it, but it's worth asking. If he doesn't do it, would it make sense for me to replace them (I do know how to solder fittings)? Would it make sense for me to replace that rubber coupling?
    Again, I'm looking at this as a lesson learned.
    Thanks again.
  15. hj
    I am not sure WHY he used the rubber coupling when all he had to do was solder a stub of copper into the tee. He did a "quick and dirty" installation, but I am sure he was the cheapest "plumber" you talked to. Most plumbers are also sewer cleaners. Few "sewer cleaners" are plumbers.
  16. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    He was the only "plumber" I spoke to, actually. Would it make sense for me to replace the rubber coupling with a length of copper? What about the compression fittings?
  17. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I would say for the price that you paid, It was a job well done...
  18. Tom Sawyer
    Nov 29, 2010
    Maine
    I would bet because he didn't have the copper or the fitting and it was a whole lot easier and cheaper to hack what he hacked.
    And this was done in Massachusetts which further confirms my opinion regarding the lack of supervision of Mass plumbers. The license in Mass is a joke in most areas because they don't have near enough inspectors to check on things
  19. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Here's a follow up. I emailed the plumber today and told him that I showed a picture of the installation to a plumber (I didn't say 'multiple plumbers on the internet'). I said that my main concern at this point is the compression fittings that won't be accessible. He emailed back stating that it is not a code violation and that there is no issue but that he would change them out for me. Then a few minutes later he emailed me again stating that he looked in his code book and whoops, made a "stupid mistake" as he put it. He is telling me that he will make right on this and wants me to be satisfied. To his credit, he may not be competent, or a plumber, but he seems to be upstanding in this sense. Another thing that made me question his competence when he was here was that he recommended that I remove the rigid metal dryer vent (near the floor) and replace it with an ABS pipe that goes has three 90 degree bends (going up the wall, across, and then down the other wall). My understanding is that ABS is not good to use for the dryer vent, and that multiple bends are not good. He told me that if I got the parts, he would help me install it without charging. Again, my take is that this is a bad idea.
    What do you guys think?
  20. Terry
    Aug 17, 2004
    ABS pipe burns pretty good. I would never run a dryer vent in material that melts and burns.
  21. jimbo
    jimbo Plumber
    San Diego, CA
    I believe any building code prohibits plastic pipe for dryers. They don't even allow the vinyl flex lines, which used to be common for dryer hook ups. This is building code, not plumbing code.
Similar Threads: plumber installed
Plumbing Forum, Professional & DIY Advice Drain Question for the experts, Local Plumber installed shower drain question. Aug 13, 2013
Plumbing Forum, Professional & DIY Advice Is this a correct install? Pic of Shower and Toilet Drain installed by local plumber. Oct 24, 2012
Plumbing Forum, Professional & DIY Advice Plumber installed our toilet to the pump?? Feb 3, 2008
Plumbing Forum, Professional & DIY Advice Any idea what a plumber might charge for repairing a copper pipe? Mar 19, 2017
Plumbing Forum, Professional & DIY Advice Happy World Plumbing Day! We Celebrate By Interviewing ... A Plumber Mar 11, 2017
