Alex Lipowich
I've got the dreaded Error Code 6.
I have a pair of hot water heaters next to each other, different models. Older one working for 10+ years, the twin sister one died, and was replaced about 7 years ago with this now out of warranty and problematic heater. It has worked flawlessly since installed.
Suddenly Error 6: I drained 1/2 a gallon in case there was sludge, I purged it a bit to clear that out. I went outside to confirm no blockage of the vent, and on start up with it running and burner on, it seemed to blow outside just as hard as the one next to it with its own vent.
Reading up, error six could be low gas supply. I doubt it. On reset, the burner lights up immediately, and seems just fine. Neighboring HWH works great. Same for voltage and polarity of supply. No change over the years. All indications so far from reading would be possibly the flame sensor. I did shut off gas, unlug, and remove the burner unit. I lightly sanded flame detector with a 600 grade sandpaper, it appeared lined up according to the specs I can find online. I re-installed all this, and still, although it fires right up, when I come back in 30 minutes, it has cycled off, and has this code.
I hate to "throw parts" at a problem, any ideas what to do next?
