A dumb mistake on my part
Discussion in 'Toilet Forum discussions' started by pjw, May 16, 2009.
  1. pjw
    pjw New Member
    Apr 1, 2009
    NJ
    I was recently installing a toilet in my house when I became distracted and tigtened a tank bolt a bit too much and heard that little "Tink!!!" that we all hate to hear. My fault entirely, but I do have a question to throw out:
    Since bathtubs are made from acrylic (or fibreglass, or whatever), why not toilets? Is there some universal law that they all must be porcelain?
  2. hj
    toilets
    There have been plastic replacement tanks in the past, notably by Gerberit, and Delta made a plastic one piece toilet years ago, but they were notable for their failures to create a demand.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There have been cheapo toilets that have come and gone that we plastic. Never worked out as being reliable and they had quality problems in general. Here's what you actually did wrong. When you are connecting the tank to the bowl, you should alternate from side to side, just snugging the nut before changing sides. Back and forth several time, erring on too many changes. Sometimes the tank does not end up actually touching the bowl. Just go you feel and always alternate tightening the nuts. On a related topic, when setting the toilet on the wax ring, don't use the flange bolts to pull the toilet down. Use you body weight to mashed the horn into the wax until the skirt is on the floor all around. Then just snug to bolts. The purpose of the flange bolts is just to hold the toilet in place in case of being bumped.
  5. Terry
    Aug 17, 2004
    hj,
    I remember the Delta one-piece plastic toilet.
    The showroom where I worked had a red Delta one-piece toilet.
    It was so light, it felt more like picking up a beach ball then a toilet.
    The year was 1974
  6. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    You may be fine with that "tink." That doesn't necessarily mean you "cracked" the toilet. A rough edge may have just "flattened" out. Ok, I'll knock it off with the "quatation marks."
    Also Gary, a poster recently got some :) awesome :) advice from Toto in regards to their tank to bowl gaskets. Soaking them in warm, not hot water mind you, will help you get three points of contact.
  7. hj
    gasket
    Good luck finding "warm" water in a new house which does not have a stove, or even gas yet. If the gasket needs to be "warmed up" then it is either too thick or too stiff.
  8. Terry
    Aug 17, 2004
    hj,
    The gaskets are fine.
    The biggest problem we have is homeowners cracking tanks by tightening too much.
    We just push the tank down with hand, and tighten with the other.
    Seems easy.
  9. kingsotall
    Aug 17, 2008
    Well, in your neck of the woods I would say leave it on the sidewalk next to the eggs that are frying. Give it two minutes. Same goes for the eggs. :)
  10. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I always sit on them & wiggle around a bit to seat them
    No - I'm not a big guy ;)
    So far no cracks or leaks
  11. kingsotall
    Aug 17, 2008
    Interesting visual of a man on top of a tank squishing down the gasket!
  12. Joe the Plumber
    Joe the Plumber Pluumbing, of course
    Oct 15, 2008
    Waht the heck?
    Yu sit on the gasket?
    nad then wiggle around?
    Dude, use your hands.
    Yru thinkng with teh wrong part of your brain.
  13. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    are you sure what happenned???
    Usually when I hear that " tink noise"
    it usually means tha tI have tightend down the toilet too much and I have broken either the toilet bolt,
    or worse yet I have broke the plastic toilet flange....
    and that is when the crying starts....
    I have not done that in decades.....
    as far as the seal, I always warm them up in the
    lavatory in hot water for a few minutes before I set
    a toilet..... it makes it all warm and fuzzy and sinks down easy
  14. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    No, the toilet - once in place - duh :D
  15. wooo stash
    wooo stash New Member
    Mar 7, 2009
    Toilets are made of Stainless Steel in prison.....I know what you people are thinking~and NO I have never been to prison!!!
Similar Threads: dumb mistake
Toilet Forum discussions Really Dumb Question: Toilet Seats Jun 17, 2014
Toilet Forum discussions dumb questions about installing drake Mar 20, 2006
Toilet Forum discussions 10 inch rough in by mistake Feb 27, 2014
Toilet Forum discussions Dropped toilet -- $200 mistake? Jan 22, 2006
