A/C condensate lines
Discussion in 'HVAC Heating & Cooling' started by bounced, Jul 5, 2009.
  1. bounced
    bounced New Member
    Jan 28, 2008
    Georgia
    [​IMG]
    Happened to notice this down in the crawlspace a few days ago and I've got a few questions for those more knowledgeable since this looks... problematic :p .
    1. The secondary condensate outlet is dripping occasionally, even though I checked the primary line and it is flowing too. Is that unusual? It's probably relevant that the primary line is not perfectly sloped. There's a couple of pipes leading to the septic tank in the way and only about a two inch difference between the height of the outlet and the hole that been drilled to the outside ten feet away. So there's a section that's pretty level and then it slopes upward slightly before heading outside. Do I need to correct the slope? Regardless, should I put a trap on the primary line?
    2. I assume the secondary outlet should have at least a trap on it (there's quite a bit of air blowing out it, needless to say), and probably should be run to the outside too? Obviously, the current drip is rusting the unit and putting moisture in the crawlspace.
    Thanks for any advice!
    x-posted to diychatroom
  2. jadnashua
    The secondary drain should only have flow if the primary drain is backed up or blocked. All of the manufacturer's instructions call for a trap on the line that I've seen. Under ideal situations, you'd notice when there was discharge from the secondary and have it trigger some alert so you could figure out what's wrong.
    You really want something like 1/4" per foot slope from the output of the trap you need to install.
Similar Threads: condensate lines
HVAC Heating & Cooling Condensate pump bad? Oct 22, 2016
HVAC Heating & Cooling Condensate + attic install + gravity = bad Sep 11, 2016
HVAC Heating & Cooling Backed up drain (condensate?) line still after using shop vac Aug 30, 2015
HVAC Heating & Cooling Condensate Pump Question Jul 10, 2014
HVAC Heating & Cooling Condensate Line Clog Jun 25, 2014
