'96 Gerber
Discussion in 'Toilet Forum discussions' started by jeffdt, Jan 31, 2010.
  1. jeffdt
    jeffdt New Member
    Dec 28, 2009
    Atlanta area
    I have a '96 Gerber thats original to my powder room, home was built in '96. I don't know what the model is, inside the tank it's stamped 28790 and 1.6 i'm assuming it's a 1.6 gallon. In any case it performs very poorly, requiring 2-3 flushes, if you don't flush incrementally and try to flush once after business is done it will clog. I will replace with a Toto after x-mass recovery occurs. Inside the tank (new fluidmaster fill valve and flapper) there is a large plastic cylinder that surrounds the overflow tube. Is this cylinder how they made it a 1.6 gal flush? If I were to take a snips and cut a deep v notch maybe 4-5 inches deep down from the top of this cylinder would this allow more of the tanks water to reach the flush valve affording me a more powerful flush? Also, the water spot seems entirely to small. I need to get a few more months out of this thing.
    Thanks,
    Jeff
  2. jadnashua
    First thing I'd try is to just hold the handle down until the tank is empty and see what happens. As to the water spot, unless you have a bad fill valve, or one not designed for it, the bowl is probably what it is. Take a bucket and slowly add water to the bowl. If it goes up and stays up, the fill valve isn't balanced to provide the needed bowl fill. If it never rises, or doesn't stay up, that's the way it is and nothing you can do will cause it to rise.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    That was one of Gerber's first attempts at 1.6 gal. flush. It was never that good. If you cut the bucket out you will get a better flush with a lot more water. OK for a temporary fix but suggest you replace it as soon as possible.
    John
Similar Threads: Gerber
Toilet Forum discussions Gerber tank modification Oct 14, 2016
Toilet Forum discussions Gerber HE-21-872 toilet with pictures Aug 6, 2016
Toilet Forum discussions Gerber Ultra-flush not working well since pressure regulator added Mar 26, 2016
Toilet Forum discussions Case 3000 replacement with Gerber Maxwell Mar 2, 2016
Toilet Forum discussions Gerber avalanche or AS VorMax? Dec 30, 2015
