90 degree adaptor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by David95966, Sep 25, 2013.
  1. David95966
    David95966 New Member
    Sep 1, 2013
    Oroville, CA
    I want to install a wall mount sink and faucet, but my water supply cones from below the sink. I've attached photos of the kink of sink I'm interested in that seem to have done this. There appears to be a 6" box behind the sink containing the water which does not come from the wall.
    My question is, how does the line turn 90 degrees from vertical up to horizontal? Is there an adapter that turns the 90 degrees? If so, what's it called?
  2. David95966
    Sep 1, 2013
    Oroville, CA
    Would this work?
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You didn't tell us what kind of pipe and fittings you have to work with, so it's a bit difficult to say exactly what you should use. The thing pictured is basically a street elbow. It has a male end and a female end. It very well might work if the thread match what you have. It's sure not what I would use however. I'd cut the pipes off and solder an ordinary copper street ell on the pipe then get proper adapter for your sink supply.
  5. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    A 90* connector is called elbow or ell.
Similar Threads: degree adaptor
Plumbing Forum, Professional & DIY Advice 30 degree bend? Jan 21, 2017
Plumbing Forum, Professional & DIY Advice 1 22 degree and 5 90s before main - Clogged Jun 10, 2016
Plumbing Forum, Professional & DIY Advice P Trap at 90 Degrees to Shower? Feb 15, 2016
Plumbing Forum, Professional & DIY Advice Starting a vent with a 45 degree angle Jul 22, 2015
Plumbing Forum, Professional & DIY Advice Moving toilet in house built in 1962 - help with 90 degree w/ low heel. Apr 10, 2015
