6" Certainteed Pipe splitting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by crw1957, Apr 28, 2008.
  1. crw1957
    crw1957 New Member
    Apr 26, 2008
    I have made 5 repairs to a 6" water line since October. The line is 6" SCH 40 Certainteed pipe. The line is splitting at various locations. We install a clamp and cover it up. The line feeds a 130 unit apartment complex. The pressure fluctuates from 55 to 75 PSI. Any ideas?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Time to replace the line?
  4. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    What is this, metal or plastic?
  5. crw1957
    crw1957 New Member
    Apr 26, 2008
    This is a plastic line. Yes, it may be time to replace however, I am trying to do what I can to avoid that cost for my customer.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    He needs to bite the bullet before you have a catastrophic failure.
    Better to have it down when every one is expecting it rather than suddenly when it will be extremely annoying.
    The cost may be even higher if it is done on an emergency basis.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    With the repair approach eventually you will get that whole new line. In the end the piecemeal replacement will cost far more than just doing it right the first time.
    What is this clamp you are installing?
Similar Threads: Certainteed Pipe
Plumbing Forum, Professional & DIY Advice Supply Line Pipe Type & New Stop Valve Yesterday at 1:46 PM
Plumbing Forum, Professional & DIY Advice Sealing pipe through concrete Friday at 11:26 AM
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Feb 20, 2017
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
