5" inside diameter toilet flange - cast iron
Discussion in 'Toilet Forum discussions' started by k.look, Nov 28, 2004.
  1. k.look
    k.look New Member
    Nov 28, 2004
    I have a 5" inside diameter toilet flange that's 1 1/2" deep that's connected to a 4" inside diameter cast iron waste pipe. The problem is wax rings are made for 3" and 4" openings. Is there a wax ring for a 5" opening or what do you recommend to reduce the opening to 4"?
    Ken - Chicago, Il
  2. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Regular Wax
    A regular wax should fit. The inside of 4" or 4 x 3 flanges are almost five inches. I have not hear of a 5" toilet flange.
  4. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Wax Gasket
    Although I never had this problem...
    Instead of reducing the (closet flange) drain opening you would be better off combining a small section of a second wax seal to another one to make the diameter larger if that's what you need to do.
  5. hj
    flange
    Apparently the 4" cast iron pipe is not long enough to reach the surface of the flange, the way it should. A plumber would caulk a section of pipe inside the flange so the new opening would be correct for a wax ring.
  6. k.look
    k.look New Member
    Nov 28, 2004
    flange
    EJ,
    What type of pipe do you recommend caulking in there? What will fit? A piece of iron pipe or PVC? I think if I reduced the opening down to an inside diameter of 4", the wax ring would give me a better seal in the long run so I don't have to repair the floor again. The plumbing guy at local Home Depot said this might be a commercial fitting that was put on my toilet.
    I just talked to a commercial plumbing supply house. Apparently my situation is common plumbing technique in the Chicago area. The flange is 5" diameter with a 1 1/2" drop connecting to a 4" waste pipe. A regular wax ring should do the trick. Apparently, the original installation had a plumber's putty like consistency that reduced this 5" opening to about 4" (this material was very stiff and flaking) when I originally removed it.
  7. hj
    5"
    The "5"" flange is really a 4" one, but the 4" pipe is too short. The best solution would be a 1 1/2" piece of cast iron pipe caulked, (leaded), into the flange to raise the 4" to the finish floor elevation. Failing that a piece of 4" ABS or PVC could be inserted and siliconed in place so it lines up with the existing 4" pipe.
  8. DocDee
    DocDee New Member
    Feb 12, 2015
    Maryland
    I had exactly the same problem with a cast iron flange with 5" ID (construction around 1970).
    My solution which worked perfectly was a one-piece neoprene seal from http://saniseal.com/
    "The Green Gasket" was purchased from Home Depot for about $11.
  9. JMac
    JMac Member
    Dec 29, 2014
    Florida
    Before others start flaming here, I would like to point out the date on the last post before yours : hj, Nov 29, 2004
    That's right... over 10 years ago.
    And responding to just one post (instead of the 3 old posts like you did) would have been enough for anybody new trying to find an answer to this.
  10. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Those were 3 identical posts. Think he is a fake getting ready for some spam posts? You don't suppose that SS would be paying an S E O (paid spammer) guy, do you? Those S E O guys don't usually respond. Maybe I am too suspicious. I put the space into the 3-letter acronym because they do search for that term.
  11. JMac
    JMac Member
    Dec 29, 2014
    Florida
    I hadn't read all 3 at that point, just saw them on the forum listing. I do agree with you re spam, especially after reading all 3 threads, but I was giving the guy the benefit of the doubt there. This also makes me rethink the SS, if no other reason than because of doing this.
Similar Threads: inside diameter
Toilet Forum discussions Inside diameter of Toilet flange too big! May 15, 2011
Toilet Forum discussions Dripping Sound from Inside of Wall/Ceiling When Toilet is Flushed Jan 15, 2017
Toilet Forum discussions Slow Leak inside the bowl... even without the tank! Apr 18, 2016
Toilet Forum discussions Inside of toilet PVC pipe has cut marks - an issue? Aug 23, 2013
Toilet Forum discussions exception to the rule about not using inside coupling closet flange on 3" ABS? Jun 1, 2013
