5/8 Fitting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pvoight, Jul 2, 2007.
  1. pvoight
    pvoight New Member
    Apr 19, 2007
    I am in need a fitting to redo my plumbing in my basement. I am look for a 5/8" female threads with a 3/4" solder on the other end. Anyone know where I could get this online. Box stores do not have 5/8 anything.
    Like this:
    [​IMG]
  2. Cass
    Cass Plumber
    Nov 12, 2005
    What do you have that has 5/8 thread that connects to plumbing
  4. pvoight
    pvoight New Member
    Apr 19, 2007
    Badger water meter
  5. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Call your local plumbing supply house or water works supplier...
    It should be available or they can tell you where to get it....
  6. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    I see 5/8" and I think it's 1/2" in HVAC terms, but I looked them up and sure enough...
  7. hj
    There are not 5/8" anything other than solder fittings. Your 5/8" meter should have 3/4" pipe threads, but could be 1" pipe threads. However they are "straight" threads and seal with a gasket, so you really need a water meter tailpiece to connect to it. Besides, the utility would be very unhappy if you screwed a fitting onto their meter and they had to unscrew the meter to replace it.
  8. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Has anyone here ever seen a meter with 5/8 threads? Or a 5/8 copper supply line?
    I've seen 5/8 FPT threads on some old brass sprinkler head bodies, where the sprinkling mechanism was threaded in. Rain Jet was the manufacturer.
  9. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    not too many years ago a young Master Plumber sent me on a wild goose chase to get a 5/8" (or was it 3/8"?) threaded fitting... just like the one in that picture above. I got one. Hours later I called the manufacturer of the device that the young plumber was going to connect; they told me it was 1/2" NPT. That explained the confusion. Before going out to get the "right" fitting I had asked the plumber to show me why we needed it, and he showed me but I cannot remember how it came to be that he drew that conclusion, but he did show me that one thing or another didn't fit on it... I wish I could remember now, just for my own curiosity.
    So maybe you have been through the same process and come to the same conclusion. Have someone else take another look, to see how they would get a more standard size to thread onto it...
    david
  10. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    I just did two 3/8" IPSX 3/8" compression angle stop replacements last week...they're somewhat obsolete, used on lavs & closets on older homes (with a factor value of 1 on water lines).
    Most residential gas dryers & cooktops are 3/8" IPS on the inlet...residential dishwashers are 3/8" brass also.
    I do have a full stock of 5/8" adaptors, fittings and nipples on my truck as well.
    No, I don't...kidding.
  11. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Most of the meters in the small towns I plumb in have 5/8 embossed on the them. The 5/8 means the opening size. 3/4" meter nipples are included.
  12. hj
    meter
    5/8" is the size of the meter openings, not the connections to it.
  13. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I always keep 5/8" meter tabs on the truck...and those specific washers. Very rare to see the larger type meters anymore.
Similar Threads: Fitting
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice What fittings are there for polybutylene pipes? Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Uponor PEX with non-ProPEX fittings Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Viega press fittings for PEX Sep 12, 2016
Plumbing Forum, Professional & DIY Advice Spinning PEX fittings Sep 3, 2016
