40' shellow well with a 2" casing
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by papa, Dec 11, 2008.
  1. papa
    papa New Member
    Dec 11, 2008
    :(I have a 40' shellow well with a 2" caseing. I can not find a pump with enough lift for the well with that size caseing. What can I do short of drilling a new well?
  2. W.O.P Jeff
    W.O.P Jeff Junior Member
    Dec 12, 2008
    Service and Sales Rep For Pump Company
    Ottawa, Ontario
    Where's the static water level in your well?
    Get yourself a shallow well jet pump if the water level is high enough, and then drop a chunk of poly down to the 30-35' mark and away you go.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Static Water Level?
    Whether a shallow well pump can pump water from a 40' well depends on the depth to the water from the surface (Static Water Level) and the gallons per minute (GPM) that the well can supply. A shallow well pump can effectivly pump water down to 22'.
    An impractical solution is to place the pump 20' in the ground by the well. Such as digging a large diameter (dug well) to 20' and placing the pump in the dug well and connect the pump to the 40' well at 20' ft.
    I've done this in developing countries where there is no other option other than drilling a new 4" well and installing a submersible pump.
  5. W.O.P Jeff
    Dec 12, 2008
    Ottawa, Ontario
    Yeah... Meant putting it down that deep to avoid running out of water and running the pump dry.
Similar Threads: shellow casing
Pumps and Tanks Well Forum & Blog. Water is life. 40' shellow well with a 2" casing Dec 11, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Need help ID'ing the well/casing Please! Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Cleaning well casing Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure tank in casing? Jan 23, 2017
Pumps and Tanks Well Forum & Blog. Water is life. How to remove casing on jet pump? Jan 6, 2017
