chris.b
This 4" Cast Iron (1o0~ yrs. old) is servicing a 3-story gutter, and drains into the horizontal soil pipe (10~ ft. before the stack). To replace this with PVC, what would normally be done (e.g., to comply with UPC/IPC)?
The trap appears mandated by Philadelphia code (gutter <12ft. from a window):
P-1001.5 Traps.
Leaders, yard drains, and other storm drains connected to a combined sewer shall be effectively trapped, except that inside leaders connected to roof outlets are permitted without traps if they are not located directly below a door or window or other ventilating opening of the same or an adjacent building nor within 12 feet of such an opening.
... which is fine, considering what could go down the gutter. However, are fittings like this even made in PVC? I've seen 4" PVC P-Traps available, but how do you go about a functional clean-out? I've only seen 2 in. and below P-Traps with (sediment) clean-outs available from manufacturers.
Thanks,
P-1001.5 Traps.
Thanks,
