4" recessed lighting remodeling versions...
Discussion in 'Electrical Forum discussion & Blog' started by chris fox, Nov 13, 2007.
  1. chris fox
    chris fox Member
    May 9, 2007
    near phoenix AZ
    I was told that black powder coated 4" recessed can lights are not suitable for bathroom settings(HD guy) but said the white coated versions are? Is there any truth to this, I say no.
    Another question is, are there 4" recessed lights(remodel versions that mount through the hole) that allow insulation to tough? Most I see are 3" min.
    thanks
    Chris
  2. jadnashua
    I've seen IC rated recessed, but not in remodel configurations. SOmebody may make them, but since they need to be bigger, I'm not sure how you'd get them through the hole. While somewhat of a pain, it may be better to cut a hole in the ceiling, install the new IC (and preferable AT) unit, then patch the ceiling. My preference would be to also make it air tight (AT), otherwise, you may be putting a bunch of vapor up into the insulation, and getting things wet.
  4. PEW
    PEW DIY Senior Member
    I agree with Jim, go with IC and AT, if you have attic above (and room) you could install from above. As to the color of the trim kit, personal preference.
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Where in the bathroon?
  6. chris fox
    chris fox Member
    May 9, 2007
    near phoenix AZ
    The recessed lights are pretty common at HD/Lowes etc. Lite On is what comes to mind, dont have one in front of me.
    Basically its a can with a arm that leads to a wire box. Its meant to push up thorugh a round hole and has clips in the can to secure to sheetrock.
    I was told and written on the can these need 3" clearance from insulation, so I was tryign to find if there is such a remodel can that can touch insulation?
    In the bathroom, pretty much all over replacing larger 6" cans.
    Chris
  7. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Once again "the guy at Home Depo" is WRONG!
    The can does NOT care where it is installed.
    I don't know of a true 4" can (for an R20/PAR20 lamp) that is old work and IC rated. Although I don't get out much and deal with Halo and Lightolier mainly.
    Lightolier's Lytening series is both IC and non-IC in the same can. The trim selection and installation determine which applies. They do have a 5" size.
  8. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I don't think the can itself matters, but the trim kits do matter -- some are rated for showers, etc., some aren't. If the bulb is exposed, it's certainly not a good idea to put it in a shower.
  9. jadnashua
    While there are trim kits for wet locations, the can itself will be rated for either IC of AT (insulation contact or air tight). Regardless of the trim, some moisture vapor is likely to get into the can. If it is AT, then it won't migrate into the insulation and being IC rated, likley hot enough so that the dew point will be quite high, meaning it is less likely to condense in the first place. A can that is not AT is designed so that it has air exchange, partly for cooling purposes, to limit the temperature rise, and is likely to be be coupled with a can that is probably not rated for IC - that air has to come from someplace.
  10. chris fox
    chris fox Member
    May 9, 2007
    near phoenix AZ
    thanks everyone. I used the 4" recessed and pulled the insulation away to the 3". The insualtion is on rolls(paper backed) and didnt have too mnay ideas on how to get the insualtion away, I ended up using 1x2 to prop the insulation away and secured it. I hope thios isnt a no-no?
    Chris
  11. dinkledoodle
    dinkledoodle New Member
    Jun 14, 2009
    Clearwater, Florida
    It has been a while since this question we asked. Sorry if this has since been answered, but I am search challenged...
    Has anything changed? Is anybody offering 4" IC rated recessed lighting remodel housings yet? Has anybody come up with a clever little pop in spacer suitable for blown insulation.
    TIA
    anthony
  12. lightguybc
    lightguybc New Member
    Jan 12, 2010
    Vancouver, BC
    I use a local manufacturer called Twice Bright Lighting http://www.twicebright.com They sell 4" IC remodel cans.
  13. chitownsparkie
    chitownsparkie New Member
    Jan 16, 2010
    Chicago
    4" can In bath
    Sure you can use any size recessed light in your bathroom but I don't know of any 4" remodeler, non-ic or ic that has a shower trim!
Similar Threads: recessed lighting
Electrical Forum discussion & Blog Future Size of Recessed Lighting Cans? Apr 21, 2016
Electrical Forum discussion & Blog Recessed Lighting Options for Kitchen Jan 14, 2015
Electrical Forum discussion & Blog Recessed lighting and vent fan in shower Dec 19, 2009
Electrical Forum discussion & Blog Help - guidance on recessed lighting Feb 23, 2009
Electrical Forum discussion & Blog Recessed Lighting Help Needed Dec 14, 2008
