4" Plastic Tube in Brine Tank Cracked
Discussion in 'Water Softener Forum, Questions and Answers' started by TJanak, Nov 3, 2011.
  1. TJanak
    TJanak Member
    Sep 9, 2009
    South TX
    The vertical 4" plastic tube that has the float, etc. inside it has cracked at the bottom. The cracks begin from the uppermost slit in the tube and looks like they were caused by the salt grid being pretty tight around the tube and the weakness caused by those slits.
    I guess I need to replace it, but need to know where to get one.
    I thought about using schedule 20 pvc in 4" but the OD is too large. Maybe there is a 4" OD pvc tubing? The stuff that's in the tank currently seems pretty brittle.
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
  4. TJanak
    TJanak Member
    Sep 9, 2009
    South TX
    Thanks.
    Travis
Similar Threads: Plastic Tube
Water Softener Forum, Questions and Answers Plastic Smell with softener Sep 15, 2016
Water Softener Forum, Questions and Answers If I needed to repair my Fleck 7000 SXT, which has a plastic bypass on the valve... Jun 8, 2014
Water Softener Forum, Questions and Answers Floating black rubber/plastic? pieces in my Brine tank...help! Apr 15, 2014
Water Softener Forum, Questions and Answers Can a water softener and backwash sediment filter share same drain tube? Jan 17, 2017
Water Softener Forum, Questions and Answers Riser tube glue ? Aug 23, 2016
