4 inch riser clamp
Discussion in 'Remodel Forum & Blog' started by rockycmt, Sep 22, 2009.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    I am cutting out some cast in my basement. I want to reinforce the riser to the first floor. I went to ********* and the riser clamp they have needs to go above the subfloor. I want to support from the bottom. Do they make a riser clamp that screws into the floor above.
    thanks In adv,
  2. hj
    clamp
    You put the clamp around the pipe, then use bolts in the space between the arms on either side.
  4. jadnashua
    You want the anchors to be in shear rather than in tension. On the building where I work, they just let the arms of the clamp sit on the concrete floor around the hole.
  5. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Can you support from above and recess in to the floor?
    You could find some type of angle bracket to attach to the riser clamp that can then be attached to the floor.
  6. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    It's just like You
    Would You like Your whole body weight supported by Your feet, or do You prefer to hang by Your ears? I'M BACK! :D
  7. Lakee911
    Aug 23, 2005
    Columbus, OH
    FWIW, when I was little my sister used to come up behind my and squeeze her hands around my head over my ears and pick me up.
  8. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    She needs a spanking ! No,:D I'm Married
Similar Threads: inch riser
Remodel Forum & Blog Finishing basement - 1 inch of height to spare for all flooring Dec 17, 2015
Remodel Forum & Blog 15 minute thermal barrier at top of 2 inch xps foam boards. Oct 23, 2014
Remodel Forum & Blog 3 inch Pipe for a new toilet upstairs through 2x8's or headers? Mar 16, 2013
Remodel Forum & Blog Raising floor in mudroom 4 inches and putting in tile? Jul 27, 2012
Remodel Forum & Blog Exhaust fan .. 6 inch duct redcucing to 4 ? Jul 30, 2011
