4 Inch PVC Sewer Line Through Cinder Block Foundation Wall In Crawl Space
DanMcD
Dayton, OH
Do you need a protective sleeve to bring a 4 Inch PVC sewer line through the hole in my Cinder Block Foundation Wall?
My plumber says no. Also, they seal the hole so water does not enter my crawl space.
IF you put a sleeve around the pipe, then you have to seal the sleeve AND the pipe. THe only time I use a sleeve is when I give it to the block layers and they put it into the wall and I run the pipe through it later.
DanMcD
Dayton, OH
So what is the reason/rationale behind the code in NC to require using a sleeve any time time a pipe is run through a foundation wall?
A sleeve might allow you to replace the pipe at some later time without having to break the wall. Depending on the temperature extremes, a sleeve might allow the pipe to expand and contract without rubbing on the concrete. Some soils swell and shrink depending on their moisture content and a sleeve might allow a little flexibility so the pipe isn't rubbing or flexing directly in the concrete wall.
