4" grommet but existing pipe is 3"
Qwertyjjj
I'm in the process of replacing a sewage basin. The house waste pipe that goes into the old sewage basin is 3" yet I have a 4" grommet and 4" hole in the new basin. How can I seal this up properly?
Montreal, Canada
If the "house waste pipe" has standard O.D. size as typical abs/pvc dwv pipes, then you can use an adapter.
They even have rupper no-hub couplers that that reduce different sizes.
Qwertyjjj
So you use the adapter in reverse, like an expander instead of a reducer?
Cacher_Chick
Test, Don't Guess!
You always go bigger in the direction of flow. What you want is a 4x3 spigot flush bushing, or you use a stub of 4" pipe into the basin.
Qwertyjjj
then why are they called reducers? :) That would be smaller in the direction of flow.
