4" Cast Iron toilet drain too tall
Discussion in 'Toilet Forum discussions' started by panawop, Nov 29, 2008.
  1. panawop
    panawop New Member
    Nov 29, 2008
    Novice remodeling 80 yr old bathroom... the original 4" cast iron pipe for toilet drain sits 1-1/4" above subfloor without a flange.
    What's best, looking for a cast iron flange or trying to break the pipe and tie into pvc with rubber boot? (finished floor will still be 3/4" short of top of pipe)
    Any suggestions would be much appreciated...:confused:
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Cast iron can be a problem for DIYers. The very best thing to do is to hire a plumber to properly install a flange at the correct height. If you determine to DIY, then shortening the pipe and installing a flange with a no-hub connector would be the best option to professional help. You do not use a "rubber boot". These are intended for buried connections only. I'm not sure by your description if you are aware that the flange is supposed to set on top of the finished floor. In addition to the drain connection, it is anchored with screws through the finished floor and into the sub floor. I'd recommend you get the floor completely laid leaving the pipe extending through the floor then call the plumber to do the flange work. That would be the best way.
  4. panawop
    panawop New Member
    Nov 29, 2008
    Thanks! Unable to afford a pro @ present. But may try a CI flange that inserts the pipe. All suggestions are welcome!!
  5. hj
    pipe
    If you use an insertion flange, which I would NEVER use unless it was a very special situation, how do you plan to cut the pipe off?
Similar Threads: Cast Iron
Toilet Forum discussions How to connect back outlet toilet to cast iron soil stack? Oct 22, 2016
Toilet Forum discussions Cast Iron Soil Pipe & ABS/PVC Offset Flange Sep 11, 2016
Toilet Forum discussions Basement Toilet, no flange & looks like cast iron Jul 3, 2016
Toilet Forum discussions Toto legato & cast iron pipes Jun 1, 2016
Toilet Forum discussions Removing 1" of Cast Iron Feb 28, 2016
