36yearoldlife
Hello everybody:
I have a 4 ton pump and dump geothermal system in use since 2005 and connected to a 36 year old well and pump. The pump has never had any issues, nor has it ever been pulled or serviced. The casing is 5" cast iron or steel. We have never had "good" water pressure in the house, but I attribute that to the water softener because there is great pressure at the spigots outside and at the pressure tank. Just not at the faucets in the house. Also, when we use the geothermal, the water pressure in the house is really bad. the geothermal is supposed to "dump" the water after it extracts the heat from it at 8 gpm. There is a valve the indicates the gpm, and it always fluctuates both up and down when the unit is on.
We want to try to use the geothermal exclusively this winter, but we are afraid we will ruin our ancient well pump in the process. I have been interviewing local well guys and most of them recommend drilling a new well. The average cost so far is 5K. I am having a hard time accepting this considering our well pump seems perfectly fine.
I need some good advice.
Do we just keep using our setup as-is?
Do we fork over the dough and get a new well?
Do we try to have the pump pulled to replace it and risk breaking it in the process thereby making it necessary to drill a new well anyway?
Is there a way for us to prolong the life of our current well pump, continue to use it for the geothermal, and improve the pressure in the house?
I sure do appreciate your help.
Jason
Jason
