36" x 48" shower base
Discussion in 'Shower & Bathtub Forum & Blog' started by FlynHokie, Feb 7, 2009.
  1. FlynHokie
    FlynHokie New Member
    Jan 25, 2009
    Williamsburg, VA
    I'm having a hard time finding a 36" by 48" shower base. Is that an abnormal size? Our old fiberglass one piece shower stall measured that. I want to replace it with a solid surface shower base and tile the walls, but I can't find any solid surface ones that measure that.
    Any recommendations?
  2. jadnashua
    There are places that will make a custom one, but it isn't really all that bad to make your own and tile it. Check out www.johnbridge.com for some ideas and help with tiling, whether you decide to make it or not. I'd also visit www.schluter.com and review Kerdi...neat stuff. While harder to find, Wedi has a tileable system that might work for you as well.
  4. Howard Emerson
    Howard Emerson I teach guitar:You call that a job?
    Apr 28, 2008
    Huntington Station, NY
    What color?
    http://americh.com/single_product.php?item=showerbases&id=26
    They make a great base, but on second thought, this one is 'barrier free', for a wheel chair..........I'll check elsewhere.
    Found it: http://americh.com/single_product.php?item=showerbases&id=11 Ignore the picture they show, which is obviously square, but it is available in single threshold, solid acrylic, in the size you're wanting.
    Go to Americh.com and then find a local dealer.
    HE
  5. FlynHokie
    Jan 25, 2009
    Williamsburg, VA
    Thanks much!!!
    Don't want to tile the floor - I'd rather have a solid surface (mainly for cleaning purposes - don't want to mess with cleaning grout floor down the road...
    Thanks for the advice though!!! and the find!!!
  6. Howard Emerson
    Apr 28, 2008
    Hi Flyn,
    Where'd we be without Google?
    By the way, I am assuming that you meant to write '48 x 36' when you wrote the measurements.
    '36 x 48', on the other hand, is not something that is made, and it's entirely different. The first measurement is always the length unless specified differently.
    Best of luck with the renovation!
    HE
  7. turkeyvulture
    turkeyvulture New Member
    Feb 5, 2009
    California
    Kohler makes a couple of cast iron ones. Also check with your local cultured marble/cultured onyx manufacturer. Here is Sacramento, the make either one to that size and other sizes also.
  8. FlynHokie
    Jan 25, 2009
    Williamsburg, VA
    Thanks Howard
    That's probably why I wasn't getting any results!
  9. FlynHokie
    Jan 25, 2009
    Williamsburg, VA
    Transolid Shower Base
    Does anyone have any experience with Transolid Solid Surface shower bases?
Similar Threads: shower base
Shower & Bathtub Forum & Blog Shower Leak to basement... Feb 10, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Improve Shower Base Support Dec 20, 2016
Shower & Bathtub Forum & Blog Shower base install - cbu before or after? Nov 18, 2016
Shower & Bathtub Forum & Blog 60"x40" shower base/pan Sep 12, 2016
