32x60 replace tub alcove ..small room 60 x 65 24"door
Discussion in 'Shower & Bathtub Forum & Blog' started by weneedhelp, Mar 15, 2009.
  1. weneedhelp
    weneedhelp New Member
    Jun 19, 2007
    AZ
    Is it do-able?
    Installation will be done by a Plumber.
    Room is 65" x 60" entrance into is door opening of 24".
    The Bathtub will be 32" x 60" K-1219-l.
    I cannot cut into the walls of the rooms adjacent.
    But ok inside the Bathroom, hopefully the Alcove Area.
    Thanks for your help.
    Sey
  2. jadnashua
    How high is the ceiling? You'll probably need to take out anything else in the room - vanity, toilet, etc., if they are in there.
  4. weneedhelp
    Jun 19, 2007
    AZ
    The room is 98" high.
    Toilet will be removed, that is everything.
    Sey
  5. Howard Emerson
    Howard Emerson I teach guitar:You call that a job?
    Apr 28, 2008
    Huntington Station, NY
    As long as the tub is not deeper than 22" or so, you can get it in the bathroom area with no problem. In fact that particular tub, The Hourglass, is 20" deep so you'll get it in with a little room to spare.
    HE
  6. weneedhelp
    Jun 19, 2007
    AZ
    How would i get the Tub inplace once it is in the room on the 32" edge
    and upright?
    Left hand drain. Which end should be up and how would the tub be
    placed into the alcove?
    Thanks for the help
    sey
  7. jadnashua
    Stand on end, then lower, probably with the drain end up. You'll need access either from the end or beneath to make the final hookups.
  8. weneedhelp
    Jun 19, 2007
    AZ
    can you lower a 60" tub into a 60" wide alcove???
    I am not sure, but i do not want to purchase a tub that cannot be
    installed in the room.
    Sey
Similar Threads: 32x60 replace
Shower & Bathtub Forum & Blog Can't find a shower faucet replacement Feb 7, 2017
Shower & Bathtub Forum & Blog Garden Tub Moen Trim Replacement Jan 29, 2017
Shower & Bathtub Forum & Blog How do we replace 5'0 bathtub with minimum damage? Jan 5, 2017
Shower & Bathtub Forum & Blog Trying to replace shower head without pipe! Dec 12, 2016
Shower & Bathtub Forum & Blog Replace shutoff valve Dec 7, 2016
