32mm system Questions
Discussion in 'Remodel Forum & Blog' started by edlentz, Sep 7, 2008.
  1. edlentz
    edlentz New Member
    May 26, 2008
    Michigan
    Maye someone can explain something to me. I have a basic understanding of the 32mm spacing vertically for drawer slides and hinges. Each 5mm hole is 32mm from the last one vertically. I have been looking at drawer slides. Many of them say they are 32mm compatible. What does that mean? From what I have seen the vertical lines of holes don't have a width horizontally that would be consistant with the 32mm system, or did I miss something? Also, are the holes used to secure the slide? If so, how? Special screws?
    Thanks for any hints.
  2. jimbo
    jimbo Plumber
    San Diego, CA
  4. edlentz
    edlentz New Member
    May 26, 2008
    Michigan
    Thanks Jimbo for the info that is just about all I need to get started. One last one tho. Do the Varianta screws work with the 32mm compliant drawer slides? I am probably going to use Blum slides. Nothing fancy just the 75# ones
Similar Threads: 32mm system
Remodel Forum & Blog Faqs on home security systems Jul 27, 2011
Remodel Forum & Blog heated flooring system -w/ tile Nov 4, 2009
Remodel Forum & Blog Will this drain system work? Jun 17, 2009
Remodel Forum & Blog Change in DWV System shared by shower & lavatory: Is this okay? Jun 21, 2008
Remodel Forum & Blog Basement Drainage System Idea--NEED SERIOUS INPUT!!! May 7, 2008
