32 gallon 100 psi h2ow-to tank Not shutting off
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Cjdukes, Mar 6, 2010.
  1. Cjdukes
    Cjdukes New Member
    Mar 6, 2010
    south carolina
    We just had a brand new h2ow-to tank put in about a month ago. We just noticed yesterday that it is constantly running with no demand from the house. My father in law is 86 and not able to take care of this himself.
    Would appreciate any kind of advise to help rule out any situation that could be happening.
    any help would be a God send..
    Thank You
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If the pressure is not building to 50 or 60, which should shut off the pump, then you probably have a leak somewhere. If the pressure climbs high and the pump doesn't shut off, the little line to your pressure switch is probably clogged.
  4. Cjdukes
    Cjdukes New Member
    Mar 6, 2010
    south carolina
    I am sorry I should have explained that although the tank is max 100psi it is set for 45psi. So would it be under the same concept that if it builds up to 45psi and does not shut off, that it could be a leak? and if so.. how can we rule out where the leak could be coming from?? thank you again so much
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
  6. Cjdukes
    Cjdukes New Member
    Mar 6, 2010
    south carolina
    the reading when the pump wont shut off is 45psi
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Do you know what the cut-on and cut-off pressures were when the pump operated normally? The AIR pressure in the tank has to be set to at least 2 psi LOWER than the cut-on pressure when the tank is empty of all water.
    Valveman is right in that you may have a leak which would likely be in the pump's drop pipe in the well.
  8. Cjdukes
    Cjdukes New Member
    Mar 6, 2010
    south carolina
    It would cut on at 32 and cut off at 45
  9. Cjdukes
    Cjdukes New Member
    Mar 6, 2010
    south carolina
    I would like to thank you all for your help.. My husband went out and checked the pressure switch, and found it was stuck :) ...
Similar Threads: gallon h2ow-to
Pumps and Tanks Well Forum & Blog. Water is life. Why Is Pump Gallons Per Minute Rating Important if You are Using a Pressure Tank? Jul 14, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Need a two gallon tank but . . . Jun 11, 2016
Pumps and Tanks Well Forum & Blog. Water is life. I have a Leader 110 pump jet pump, a 120 gallon galvanized tank and a CSV 12540-1 Aug 24, 2015
Pumps and Tanks Well Forum & Blog. Water is life. spring fed 1000 gallon tank to mobile home to steel building - install question Oct 21, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Over 35,000 gallons in less then two months? Jul 18, 2014
