30 X 60 Tub - Anything Besides Villager or Princeton?
Discussion in 'Shower & Bathtub Forum & Blog' started by sheellah, Aug 9, 2009.
  1. sheellah
    sheellah New Member
    Aug 27, 2008
    I have a small NYC 5 X 8 bathroom and need a 30 X 60 alcove tub under 15" high as it's mostly used for showers, and a taller one is too hard to get in and out of as I get older. I'm doing a higher end look, and it's discouraging that these two seem to be my only choice. No room to build a surround.
    Are there any others? Would prefer cast iron, but any material that will hold up 20+ years would also be fine. Any ideas? Thanks!
  2. pmetiv
    pmetiv New Member
    Oct 17, 2008
    New York, NY
    We had the same issue and went with the villager. It's probably a better bet then the Princeton since the shape is a bit more interesting.
    If you don't mind having it a bit higher, the Kohler Hourglass comes in 30x60 but is 17in high....it is lower then most Acrylic tub which normally go for 20-22in high.
    Good luck!
    Pierre
  4. sheellah
    sheellah New Member
    Aug 27, 2008
    I don't think acrylic tubs hold up well. Don't they scratch and stain easily? Really want the cast iron. I can't believe there's only one on the market. The Villager is nice but I really don't like that boomerang decoration on the apron. I like the design of the Princeton better, but not the Americast.
  5. hj
    tub
    Why can't you build a surround on either tub? Millions of people have managed to do it.
  6. sheellah
    sheellah New Member
    Aug 27, 2008
    A surround takes up several inches and I don't think I have enough clearance as the toilet is pretty close. I don't even think they make anything as small as 30" wide where you can tile the apron. What is the minimum number of inches that a tiled apron can add to the width of a tub?
  7. jadnashua
    Zero...if you build a wall that is recessed the thickness of the tile, once installed, it could end up flush with the edge of the tub.
  8. sheellah
    sheellah New Member
    Aug 27, 2008
    Thanks! Didn't know that. I would prefer some edge thickness though. I think it looks better. I don't know if they make a 30" tub though with no apron at all.
Similar Threads: Anything Besides
Shower & Bathtub Forum & Blog Anyone bought anything from Tub Connection? Mar 2, 2011
Shower & Bathtub Forum & Blog Anyone know anything about this brand? Feb 19, 2009
