30" electric freestanding range wiring
Discussion in 'Electrical Forum discussion & Blog' started by ballvalve, Feb 2, 2012.
  1. ballvalve
    Dec 28, 2009
    northfork, california
    Must all range outlets be 50 amp plugs with 6 gauge or larger wire, or may I use 8 gauge wire if I have a range that has a maximum draw of 38 AMPS? Using thhn copper in conduit for the run, about 30 feet.
    I would guess the answer is what will the next guy plug into it, or is there a dedicated 40 amp plug-cord set?
  2. jadnashua
    Can't help on the gauge, but keep in mind any new wiring should be for a four-wire plug: two hots, neutral, and ground. Only when you are reusing an existing 3-wire circuit can you keep it, not on a new one. this may affect the size of the conduit you use.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Using #8 THHN copper you could use a 50 amp breaker and receptacle but if you wanted to you could use a 40 amp breaker and receptacle.
    I doesn’t matter what “might” happen with someone else all that matters is what you are connecting at the time.
    The one thing I always teach to the inspectors that take my class is that they are inspectors not expect-ors so what might happen does not matter.
  5. ballvalve
    Dec 28, 2009
  6. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
  7. hj
    #8 wire is marginal for your range, but if you use it, then connect it to a 40 amp breaker, regardless of the amp rating of the receptacle.
  8. jimbo
    jimbo Plumber
    That is true. Standard NEMA receptacles for 120/240 appliances are 30 amp and 50 amp. Of course, you can use a 20 amp, or 40 amp, breaker as the appliance dictates. Wiring must be sufficient for the receptacle used, not just for the breaker.
  9. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Gentlemen
    The breaker is installed to protect the conductors not the receptacle. It would be perfectly legal to install a 40 amp breaker and a 50 amp receptacle for a range Table 210.21(B)(3).
    What would not be legal would be to install a 50 amp breaker and a 40 amp receptacle.
    Many AC units throughout this nation are wired with less than a 60 amp conductor and overcurrent device that land in a 60 amp no-fuse disconnect legally.
  10. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    Absolutely correct. I have never wired up a 40A recpt for a range. Never. Not once.
    That's different, they don't plug in. ;-)
  11. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    A receptacle and a cord cap is nothing more than a means of disconnect. Other than the physical shape of the two there is no difference between a receptacle and a no-fuse disconnect
Similar Threads: electric freestanding
Electrical Forum discussion & Blog Electrical supply to barn and garage Feb 9, 2017
Electrical Forum discussion & Blog Electrical panel- no ground Feb 1, 2017
Electrical Forum discussion & Blog Electrical wire accidently charred. Dec 31, 2016
Electrical Forum discussion & Blog Electric baseboard installation: no junction box behind it? Nov 25, 2016
Electrical Forum discussion & Blog Another long electrical run Nov 19, 2016
