3" Tub drain replacement
Discussion in 'Shower & Bathtub Forum & Blog' started by loop1, Jul 12, 2011.
  1. loop1
    loop1 New Member
    Jul 8, 2011
    Frederick, MD
    My bathtub's "drain spud" (the flanged outlet through which the water leaves the tub) is brass, ugly, and we must use a rubber stopper in it as any "mechanical stopper" is long gone from the overflow pipe. I figured I could just remove this "spud" and replace it with a chromed pop-up fitting, or if necessary replace the whole outlet/overflow assembly with a new one in chrome (to match the other chrome bath fittings). The diameter of the flanged part of the spud is THREE inches, and no pop up or complete assembly I can find anywhere has a flange as big as 3 inches. (Well, my local plumbing supplier found a Kohler chromed complete assembly, but I cannot pay the $300 price tag.) I must have one with a full 3 inch flange diameter because the porcelain under the flange is cracked or missing and a smaller flange will show these imperfections. I have spent hours on Google looking for a replacement in chrome with a 3 inch diameter flange, with no luck. Any help will be appreciated. Thanks
  2. afrancis
    afrancis New Member
    Nov 11, 2011
    Maryland
    ANy luck?
    Hi Loop1
    Have you had any luck finding a 3" replacement flange? I would like to find 2 for my home as the smaller ones tend to have a space around their outter edge that holds water. My two tubs are from the late 40's and late 50's but need the 3" American Standard drain.
    Appreciate any clues to your success.
  4. hj
    In both cases, the 3" strainer will NOT be generic, so even if you find a new one, it would probably NOT have the proper thread, so you may have to buy the entire drain and replace everything.
Similar Threads: drain replacement
Shower & Bathtub Forum & Blog How to prepare for replacement shower drain Jun 9, 2016
Shower & Bathtub Forum & Blog Fiat Shower Drain gasket replacement. Jan 2, 2016
Shower & Bathtub Forum & Blog Shower Drain Replacement Sep 14, 2015
Shower & Bathtub Forum & Blog Replacement Bathtub Drain Questions Oct 25, 2014
Shower & Bathtub Forum & Blog Tub drain replacement & checking for leaks May 2, 2014
