3 Tanks In A Line: Venting
Discussion in 'Water Heater Forum, Tanks' started by molo, Sep 23, 2009.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    The situation is there are 3 natural gas water tanks in a line. A 40 gallon tank and 2 -30 gallon tanks (in that order from building exit point to the rear). A friend raised the question that they were not vented properly. He was worried about the available combustion air in the basement and stated that if there was not enough combustion air when the 40 gallon tank turned on it could create a pull on the rear tanks vents and pull CO into the basement. These tanks are all located in a 750 sq. ft unfinished basement. What is code on venting 3 tanks in sequence like this?
    Thanks for any replies
  2. hj
    venting
    The same as for a single tank. There has to be adequate provision for combustion air, (at least on square inch of free area for each 1,000 btu's), and the flue has to be adequate for the total btu's of all the burners.
Similar Threads: Tanks Line
Water Heater Forum, Tanks Tanks, volts and watts Nov 18, 2016
Water Heater Forum, Tanks Two water heaters, two expansion tanks May 19, 2015
Water Heater Forum, Tanks 2 water heater tanks parallel question May 9, 2014
Water Heater Forum, Tanks Are Bradford Tanks Still Having Issues? Jan 29, 2014
Water Heater Forum, Tanks Thermal Expansion Tanks Sep 24, 2013
