3 inch to 2 inch
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by teke, Mar 17, 2013.
  1. teke
    teke New Member
    Feb 25, 2013
    Massachusetts
    Question for the group. I presently have a double vanity that is drained by a two inch pipe. It is vented by a 3 inch DWV. The 3 inch waste passes through the floor and I would like to reduce it to a two inch pipe to connect to the main waste line. Would this be against code or do i need ti leave it as a 3 inch pipe. Also the distance to the waste line is around 6 feet
  2. jadnashua
    Do not confuse a vent with a drain...if it only serves as a drain for the vanity, it could probably be reduced to 2". But, it probably also has a connection to the toilet and tub, so, no, it must remain that size. And, if it is actually a vent for things below, it wouldn't pass code today, as you're using it as a drain and wet venting between floors is no longer allowed and needs to be at least that size to work well. Last kicker is that even in your own home in MA, it's illegal to do any plumbing...a pro would know what is required and how to do it properly. Many states allow a homeowner to do plumbing in their own home, but they all require a permit and an inspection. Failure to do so could get expensive and potentially dangerous.
  4. teke
    teke New Member
    Feb 25, 2013
    Massachusetts
    Jim. Thank you for the quick reply. And I understand.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm pretty sure that Massachusetts does not allow DIY plumbing at all. I'm not the plumbing police, but it would be wise to check this out...I've been wrong before, but if I'm correct you could be in deep doo doo if/when this is discovered.
  6. hj
    Your description implies that you want to take a 3" drain line, reduce it to 2", and then connect it to a 3" line. if that is actually what you mean then the answer is NO, you cannot "reduce" a drain line in the direction of flow. The distance to the drain line is completely irrelevant, and while the vent MIGHT be able to be reduced in many cases, and it depends on the code and situation, it may be required to remain 3" all the way to the roof.
Similar Threads: inch inch
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Support studs in bathroom need new how do i thread 2 inch pvc pipes thru them Feb 1, 2017
Plumbing Forum, Professional & DIY Advice Replace 2 inch x3 and one 2 1/2 to ball valve tips Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Two inch vent or one and a half vent? Aug 13, 2016
Plumbing Forum, Professional & DIY Advice Bathroom pipes go from 3/4 to 1/2 inch for total of 8 feet. will I benefit if I convert to 3/4 ? Aug 7, 2016
